Hi there,
I was wondering if anyone would be able to help?
I’ve been happily running a Nginx SSL Reverse Proxy server (followed this guide: https://scotthelme.co.uk/setting-up-le/) for some time now (swakes.uk). Since the cert expired (forgot to setup autorenew) I’ve attempted to setup another instance to cover a similar domain (swakes.co.uk).
These run separate ESXi Ubuntu instances, with different LAN IPs but the same WAN.
When I am attempting to setup swakes.co.uk, I am finding conflicts when attempting to create the certificate (pulling other cert domains in error)
I’ve currently setup port forwarding 80/443 to both setups (realizing that isn’t going to work). Both domains have A Records (* and @ pointing to WAN)
Could someone nudge in the right way? Ideally I’d like to keep them on separate VM’s with separate certs (swakes.co.uk - public facing, swakes.uk - local only)
My domain is: swakes.uk / swakes.co.uk
I ran this command: https://scotthelme.co.uk/setting-up-le/
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu)
My hosting provider, if applicable, is: DNS - Namecheap
I can login to a root shell on my machine (yes or no, or I don’t know): Y
