Two domains mapped to the same IP
This is it:
<IfModule mod_ssl.c>
<VirtualHost *:443>
  DocumentRoot ****
#  <LocationMatch "^/(?!\.well-known)">
        #send all other requests to HTTPS
#       RewriteEngine On
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
#       RewriteCond %{HTTPS} !=on
#       RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1
#  </LocationMatch>
#   RewriteCond %{SERVER_NAME} =infinity-computer-systems.com
#   RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
ServerName infinity-computer-systems.com
ServerAlias marref.org
SSLCertificateFile /etc/letsencrypt/live/marref.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/marref.org/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
  DocumentRoot ****
  ServerName marref.org
        RewriteEngine On
  </LocationMatch>
#   RewriteCond %{SERVER_NAME} =marref.org
</VirtualHost>
</IfModule>
Shouldn't that be:
My stupid mistake: it is infinity-computer-systems.com
Ok I see what you get now:
Having these two lines in the same file created that problem:
They now have separate certs, so they need separate vhost config (in order to point each name to its' matching cert).
OR
If they really do the same thing and can be combined into one DocumentRoot, one site, one cert...
Then all we need to do is put both domain names onto one single cert.
We can do that with:
sudo certbot --apache -d "infinity-computer-systems.com,marref.org" --dry-run
[always first use --dry-run - while testing]
If the sites do different things and can't be combined, then they need separate DocumentRoots, separate vhost configs, and separate certs.
Do I comment out the ServerAlias?
See my add to last post ^
My system complains about the dry run:
--dry-run currently only works with the 'certonly' or 'renew' subcommands ('run')
Are you using a futuristic version?
OK fine, go without --dry-run then.
I get this:
$ sudo certbot --apache -d "infinity-computer-systems.com,marref.org"
requested (ref: /etc/letsencrypt/renewal/infinity-computer-systems.com.conf)
It contains these names: infinity-computer-systems.com
You requested these names for the new certificate:
infinity-computer-systems.com, marref.org.
certificate?
(E)xpand/(C)ancel: E
Renewing an existing certificate for infinity-computer-systems.com and marref.org
Certificate is saved at: /etc/letsencrypt/live/infinity-computer-systems.com/fullchain.pem
Key is saved at:         /etc/letsencrypt/live/infinity-computer-systems.com/privkey.pem
This certificate expires on 2021-11-24.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for infinity-computer-systems.com to /etc/apache2/sites-enabled/000-default-le-ss
l.conf
Successfully deployed certificate for marref.org to /etc/apache2/sites-enabled/000-default-le-ssl.conf
Failed redirect for infinity-computer-systems.com
Unable to set the redirect enhancement for infinity-computer-systems.com.
NEXT STEPS:
- The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, tr
y installing it again by running:
  certbot install --cert-name infinity-computer-systems.com
Unable to find corresponding HTTP vhost; Unable to create one as intended addresses conflict; Current configuration
 does not support automated redirection
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/let
sencrypt.log or re-run Certbot with -v for more details.
Let's review the changes:
certbot certificates
And show file:
Here we go:
$ sudo certbot certificates
Found the following certs:
  Certificate Name: infinity-computer-systems.com
    Serial Number: 407a18eb353298e4a53863774d9cdbb66e5
    Key Type: RSA
    Domains: infinity-computer-systems.com marref.org
    Expiry Date: 2021-11-24 15:40:53+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/infinity-computer-systems.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/infinity-computer-systems.com/privkey.pem
  Certificate Name: marref.org
    Serial Number: 46723b8008253bf26e6d7d610fc5fc289d4
    Key Type: RSA
    Domains: marref.org
    Expiry Date: 2021-11-24 15:10:01+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/marref.org/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/marref.org/privkey.pem
and:
$ cat /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
  DocumentRoot ****
#       RewriteEngine On
#  </LocationMatch>
SSLCertificateFile /etc/letsencrypt/live/infinity-computer-systems.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/infinity-computer-systems.com/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
  DocumentRoot ****
        RewriteEngine On
  </LocationMatch>
</VirtualHost>
</IfModule>
OK!
Here we go.
Let's remove the single domain cert:
certbot delete --cert-name marref.org
Then update file:
As follows:
<VirtualHost *:443>
  DocumentRoot /home/marref_infcs_1/websites/marref_org
</VirtualHost>
Restart Apache and all should be good.
And indeed it works!
Thanks a lot for your five-star support! I really appreciate it very much.
Pleased to hear that :slight_smile:
When you do go to add another site, keep that in mind.
If it needs to be served from a different document root, then it will need a separate vhost config (and that may require using a separate cert).
In any case, Cheers from Miami :beers:
#FreeCUBA
