This method worked fine for me after a few attempts but when I uploaded my Certificate and Key, I had to do a Certificate Signing Request through my host and it all seemed to go fine but when I go to the site I get:
This site can’t provide a secure connection
www.XXXXXXX.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
The host thinks it’s a certificate error.
Has anyone seen this when generating your cert with this method?
I ran into problems on the third step “Now you begin with creating the certificates locally by defining key size and the domains:” ./letsencrypt-auto --debug cetonly -a manual -rsa-key-size 4096 -d [domain] -d www.[domain]
Using Mac OS El Capitan.
Got the following errors:
/System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:inrequire’: cannot load such file – mach (LoadError)
from /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in require' from /usr/local/Library/Homebrew/extend/pathname.rb:2:in<top (required)>'
from /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in require' from /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:inrequire’
from /usr/local/Library/Homebrew/global.rb:3:in <top (required)>' from /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:inrequire’
from /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in require' from /usr/local/Library/brew.rb:15:in'`
step 3 didn’t work for me
I using ubuntu
in letsencrypt I run this comand
./letsencrypt-auto certonly -a manual --rsa-key-size 4096 -d yourdomain.com -d www.yourdomain.com
but didn’t work display error letsencrypt-auto: command not found
can anyone help
You are replying to an old thread about OSX (lots has changed since then) and you are running ubuntu (not OSX). I’d suggest ideally starting a new thread with your issue.
Alternatively, if you don’t want to start a new thread, please tell us about your system, how you installed certbot / letsencrypt etc.
Hi
tried this on both windows(my pc) & ubuntu(aws ubuntu server)
step1 - run command git clone https://github.com/letsencrypt/letsencrypt
done successful
step 2 - run command letsencrypt certonly --manual --email admin@example.com -d example.com -d www.example.com
with my domain name
If you have done a git clone, then you need to change into the letsencrypt directory ( cd letsencrypt )
Then include the path in front of the command ( ./letsencrypt certonly … on linux )
Hey there. I had some trouble updating my certificate. I used the same command as for creating a new one but the certificate on the webhost is not correctly updated when I upload new files there. Am I missing something?
