I’m trying to get certs for a newly-purchased actual domain I’ve recently purchased. The domain is GoDaddy but the DNS is provided by DynDNS. There’s a 301 redirect from the GoDaddy domain to the DynDNS host. Certs on the DynDNS host have worked before, so I’m thinking the issue is at the GoDaddy end. Not sure what to do here.
My domain is: jayflix.xyz AND jayflix.homedns.org (301 from jayflix.xyz on GoDaddy to jayflix.homedns.org on dyn.com)
I ran this command: certbox --nginx
— names input: jayflix.xyz,www.jayflix.xyz,jayflix.homedns.org
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): jayflix.xyz,www.jayflix.xyz,jayflix.homedns.org
http-01 challenge for jayflix.xyz
http-01 challenge for www.jayflix.xyz
Waiting for verification…
Failed authorization procedure. jayflix.xyz (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://jayflix.xyz/.well-known/acme-challenge/FieumtHpHvZAZIgExSchEP0Zrh10JbSb8PCDI9p9MdE: Timeout during connect (likely firewall problem), www.jayflix.xyz (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.jayflix.xyz/.well-known/acme-challenge/3g87WgRxbLHWJdQGbddDhB4JXavY_O0HkDF7Fvd6jAA: Timeout during connect (likely firewall problem)
Domain: jayflix.xyz
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)Domain: www.jayflix.xyz
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
My web server is (include version): nginx 1.14.2
The operating system my web server runs on is (include version): Raspbian Buster
My hosting provider, if applicable, is: n/a - self-hosted
or certbot-auto --version
if you’re using Certbot): certbot 0.31.0
