Therein lies the problem...
Location #2 =
/volumes/lmimail/Library/WebServer/Documents/.well-known/acme-challenge/
But the challenge files are being save to location:
/volumes/lmimail/Library/WebServer/Documents/acme-challenge/
Try modifying:
g_ssl_lets_path ā/volumes/lmimail/Library/WebServer/Documentsā
To:
g_ssl_lets_path ā/volumes/lmimail/Library/WebServer/Documents/.well-knownā
I belive that is going to solve the problem. Thank you for all your help. Thank you for taking the time to work thur this. I do support myself and understand that sometimes its a long ways around to find something so simple.
Hal Ashmore
I donāt think it was āso simpleā.
But like any magic trickā¦
Once you know the secret it does seem simple.
Moreover, was that setting something you originally entered?
Or did the software put it there (incompletely/incorrectly)?
If it was the software of some downloaded script, you may want to alert whomever manages it.
No I manually entered it but following instructions I found. I will message them and let them know.
Thank you again,
Hal
