Trouble renewing certificate for jbmortgages.co.uk
Via Plesk - renew certificate
Error: Could not issue a Let’s Encrypt SSL/TLS certificate for jbmortgages.co.uk .
Your domain in Plesk is hosted on the IP address(es): , but the DNS challenge used another IP address: 108.59.253.82 .
Please check the actual DNS zone of your domain and make sure that the IP addresses in the DNS zone and for the hosting are the same.
Details
Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/-zua0gqGm2l9Z-c9uD82xCXkKyCLMrxZ9isLfDSiGkA.
Details:
Type: urn:acme:error:unauthorized
Status: 403
Detail: Invalid response from http://jbmortgages.london/.well-known/acme-challenge/0QjqUkCeVY3kRoxxtDZvF6vLRrz8BfA5UWie6F6ksQM: “<!DOCTYPE HTML PUBLIC “-//IETF//DTD HTML 2.0//EN”>
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p”
Linux & Plesk Oynx
Ubuntu 16.04
Fasthosts
I don’t know - I tend to use GUI and avoid root unless absolutely neccessary
Plesk Onyx
Other domains on the same server, with the same IP are renewing just fine - it’s only this domain that seems to be having the problem.
Thanks in advance for your help
Hi @jmgraphicdesign
you have one certificate with four domain names:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:jbmortgages.co.uk&lu=cert_search
jbmortgages.co.uk jbmortgages.london www.jbmortgages.co.uk www.jbmortgages.london
But jbmortgages.london has another ip address ( 108.59.253.82 ). So Certbot / Plesk cannot create the validation file there.
If the jbmortgages.london uses another server, you should create a certificate only with the two domain names jbmortgages.co.uk www.jbmortgages.co.uk
Thank you so much - yes you’re right, I hadn’t realised the alias was still pointing to the old server!
I wouldn’t have picked up on this myself, thanks for checking and pointing it out - I changed the ip for the alias and it worked straight away :slight_smile:
Yep, now
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:true;domain:jbmortgages.co.uk&lu=cert_search
there is new new certificate.
https://transparencyreport.google.com/https/certificates/I%2B3AJ9jz1O0Yw3%2BSWy8%2Fmuo%2Fvas8UmaRl6u259ysnGQ%3D
Created today, not visible at 18:25 :wink: And already installed - https://jbmortgages.co.uk/
A post was split to a new topic: Renewing the certificate on hogsellerhub.com.ng
