The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('There has been an error in parsing the file /etc/apache2/mods-enabled/php7.4.conf on line 2: Syntax error')
Apache/2.4.41 (Ubuntu)
Ubuntu 20.04.3 LTS
N/A
Yes
No
certbot 1.18.0
That second quote ” looks like it was copy-pasted from a blog or something which converted it to a Unicode quote. Try replacing it with a regular ASCII quote (") like the rest.
I've now got another problem unfortunately. Running the command:
sudo certbot --apache
Results in the following output...
Requesting a certificate for iangrainger.co.uk and www.iangrainger.co.uk
Domain: iangrainger.co.uk
Type: dns
Detail: During secondary validation: DNS problem: query timed out looking up A for iangrainger.co.uk
Domain: www.iangrainger.co.uk
Type: dns
Detail: During secondary validation: No valid IP addresses found for www.iangrainger.co.uk
Any ideas?
Will need to try resolving this tomorrow as it's after 2am here!
