Trouble creating certificate for jboss EAP
My domain is: test.bizapps4me.com
certbot certonly --webroot -w /jboss-eap-7.0/welcome-content -d test.bizapps4me.com
http-01 challenge for test.bizapps4me.com
Using the webroot path /jboss-eap-7.0/welcome-content for all unmatched domains.
Waiting for verification…
Failed authorization procedure. test.bizapps4me.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://test.bizapps4me.com/.well-known/acme-challenge/0bN-JRFLgABcw5Q0TD3N_Xf10ezstzbLMNAroOOIDho: Timeout during connect (likely firewall problem)
    Domain: test.bizapps4me.com
    Type: connection
    Detail: Fetching
My web server is (include version): jboss eap 7
The operating system my web server runs on is (include version): oracle linux 7.5
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.29.1
Additional info:
we use iptable forwarding rules to forward port 80 traffic to port 8080 where jboss listens.
Your server needs to be accessible from the external internet. Currently, no outside traffic can reach port 80 of 71.127.49.246 (nor any other port that I can find).
Are you on the system that test point to (71.127.49.246)?
Check with:
curl -4 ifconfig.me
If same, …
Is there some other firewall device inline?
Does your ISP (MCI Communications Services, Inc. d/b/a Verizon Business) block port 80?
That was it. Once it was visible outside the lan, the certificate created.
Thank you very much.
Thank you. Yes it did turn out to be a firewall issue.
