im using SOPHOS UTM intergrated Let’s Encrypt module to get certificates. Due to an DNS resolution problem on my applicance, i got the following error message:
2019:11:07-01:34:13 utmcluster-1 letsencrypt[23144]: E Renew certificate: COMMAND_FAILED: “type”: “urn:acme:error:rateLimited”,
2019:11:07-01:34:13 utmcluster-1 letsencrypt[23144]: E Renew certificate: COMMAND_FAILED: “status”: 429
UTM will try every single night to renew the certificate.
My certificate will be invalid in 29 days. Can i check for my domain, when the rate limit counter will be reseted? i want to avoid, that my site will stop working in 29 days.
I the logs i can see, that the public and private key should be under /var/storage/chroot-reverseproxy/var/lib/dehydrated/cert_data/certs but i cannot find any keys for the domain
running command: /var/storage/chroot-reverseproxy/usr/dehydrated/bin/dehydrated -x -f /var/storage/chroot-reverseproxy/usr/dehydrated/conf/config -c --accept-terms --domain www.corpus-sireo.com --domain corpus-sireo.com
2019:11:06-03:54:37 utmcluster-2 letsencrypt[18761]: I Renew certificate: command completed with exit code 256
2019:11:06-03:54:37 utmcluster-2 letsencrypt[18761]: E Renew certificate: COMMAND_FAILED: ERROR: Problem connecting to server (get for http://cert.int-x3.letsencrypt.org/; curl returned with 6)
2019:11:06-03:54:37 utmcluster-2 letsencrypt[18761]: E Renew certificate: COMMAND_FAILED: ERROR: Walking chain has failed, your certificate has been created and can be found at /var/storage/chroot-reverseproxy/var/lib/dehydrated/cert_data/certs/www.corpus-sireo.com/cert-1573008853.pem, the corresponding private key at privkey.pem. If you want you can manually continue on creating and linking all necessary files. If this error occurs again you should manually generate the certificate chain and place it under /var/storage/chroot-reverseproxy/var/lib/dehydrated/cert_data/chains/4f06f81d.chain (see http://cert.int-x3.letsencrypt.org/)
2019:11:06-03:54:37 utmcluster-2 letsencrypt[18761]: I Renew certificate: sending notification WARN-603
2019:11:06-03:54:37 utmcluster-2 letsencrypt[18761]: [WARN-603] Let’s Encrypt certificate renewal failed accessing Let’s Encrypt service
2019:11:06-03:54:37 utmcluster-2 letsencrypt[18761]: I Renew certificate: execution completed (CSRs renewed: 0, failed: 1)
N/A, cert is stored on fw appliance
Na
Yes
Sophos UTM 9.6
N/A
So if /var/storage/chroot-reverseproxy/var/lib/dehydrated/cert_data/certs/www.corpus-sireo.com/cert-1573008853.pem doesn't exist, your installation looks corrupt.
Certificate creation has worked. So it's only an installation problem. But if you have deleted these certificates, you may have to wait. Read
