I’m trying to sort out my SSL certificate on my IIS 8 server. I’m having issues with the cipher It’s old and obsolete. Now that I’ve fixed it. I’m trying to get a new certificate, but every time I do it, I get an error. My domain name is www.learntotech.co.uk Is there a way I could get another one?
I’ve stated why I’ve tried to solve the issue so many times. I’ve said that the cipher is obsolete and needs changing on the server. I fixed it, now I’m trying to get a new one. I’ve got one already. It’s using an obsolete cipher.
I know. I’ve said that in my first post that I’ve fixed it. Now, the certificate that I had was before it was fixed. Now. I want to issue a new one so it’ll work.
Use one of your existing certificates. As @ahaw021 stated, they are still valid and independent of your cipher configurations. If you have a copy of one, it should work fine with your new configuration.
Issue a new certificate including an additional name. For example, if you issue a certificate covering both www.learntotech.co.uk and learntotech.co.uk (which might be a good idea anyway), that will not be blocked by this particular rate limit, because it isn’t the “exact set of names”.
Wait until September 15, when this rate limit expires.
