TLS Failure in web-hook response
I’m using stripe web-hooks and it gives me TLS Failure in response when web-hook is triggered.
it looks like the DNS CAA is missing, also there looks to be a chain issue.
My Domain name is: https://api.test.numuworld.com
I ran web-hooks on this domain
Output : TLS Failure
My API is running on AWS
Certbot version 0.30.2
Hi @MusabAkram
please answer the following questions. That's the template of #help
Your certificate is good (output from https://check-your-website.server-daten.de/?q=api.test.numuworld.com ):
CN=api.test.numuworld.com
	19.03.2019
	17.06.2019
expires in 61 days	api.test.numuworld.com - 1 entry
But your chain is incomplete:
Chain - incomplete
1 CN=api.test.numuworld.com
Your server doesn't send the intermediate certificate. Check, if you are able to send fullchain.pem (instead of cert.pem).
The domain
CAA - Entries
Domainname flag Name Value ∑ Queries ∑ Timeout
d2ddjon14bbsx5.cloudfront.net 0 no CAA entry found 1 0
api.test.numuworld.com 0 no CAA entry found 1 0
doesn't have a CAA entry. But this is only relevant if you create a new certificate.
But I don't know the details of "stripe web-hooks", so I don't know if there is a CAA entry required. If a CAA entry is required, it's a non-standard usage of a CAA entry.
Perhaps add a redirect http -> https.
http://api.test.numuworld.com/
52.211.168.186 200 0.170 H
https://api.test.numuworld.com/
52.211.168.186 200 0.827 B
Thank you issue resolved.
