I have a TLJH instance setup and I want to setup HTTPS.
I ran the following commands with my domain
sudo tljh-config set https.enabled true
sudo tljh-config set https.letsencrypt.email you@example.com
sudo tljh-config add-item https.letsencrypt.domains yourhub.yourdomain.edu
When I connect to the domain my browser tells me I can continue to the site but that the connection is unsecure. I am not sure what Im doing wrong I want to the connection to the domain to be secure.
Hi @diplo01, and welcome to the LE community forum
Please help us in helping you by answering as much of the questions [that you should have been presented with when opening a "HELP" topic] below:
