My domain is:mscntm.tk
I ran this command:sudo certbot --apache
My web server is (include version):Apache 2.4.29 (Ubutu)
The operating system my web server runs on is (include version):Ubuntu 18.04.3 TLS - bionic
Hi @zazai
there is a check of your domain, created yesterday - https://check-your-website.server-daten.de/?q=mscntm.tk
Your www version points (via CNAME) to parkingpage.namecheap.com
So that can't work.
Checking the non-www version there is a timeout.
Checking the www version there are a lot of
ConnectionClosed - The underlying connection was closed: The connection was closed unexpectedly.
errors.
A working http website (open port 80) is required to create a certificate via http-validation.
Now there is a new check.
The ip addresses are now ok, no parking page.
But only timeouts.
Runs your webserver internal?
curl http://mscntm.tk/.well-known/acme-challenge/1234
should show a http status 404 - Not Found.
Perhaps there is a blocking firewall or a wrong port forward.
Thank you @JuergenAuer, I have fixed this now it is pointing to mscntm.tk, but still I get the same error.
curl : (6) could not resolve host: .well-known
There is only the www host defined. So try
curl http://www.mscntm.tk/.well-known/acme-challenge/1234
or add a ServerAlias with your non-www domain name.
PS: Checking your raw ip there is the same image - only timeouts - https://check-your-website.server-daten.de/?q=122.176.208.60
The problem has been solved, the router’s port mapping for port 80 was only to one spcific external host.
