Timeout during connect on cloned AMI instance
My domain is: dekk.io
I ran this command: sudo certbot certonly --standalone -d cloud5.dekk.io
It produced this output: Failed authorization procedure. cloud5.dekk.io (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://cloud5.dekk.io/.well-known/acme-challenge/wmg8q81X5CIGr4xBIEENVS8I3srjYy_9SqA-LDx9emE: Timeout during connect (likely firewall problem)
My web server is (include version): nginx, but that’s does not relevant. While running this, I stop nginx. The exact same procedure works on my other EC2 instances. The only difference is that I clone the AMI on one of those instances and try it.
The operating system my web server runs on is (include version): Ubuntu 16.04.3 LTS
My hosting provider, if applicable, is: AWS
No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
More info. My normal procedure is
Installing certbot
sudo add-apt-repository ppa:certbot/certbot
sudo apt-get update
sudo apt-get install python-certbot-nginx
Get the certificate
sudo openssl dhparam 2048 -out /etc/ssl/certs/dhparam.pem
sudo service nginx stop
sudo lsof -i:443
sudo lsof -i:80
#now get the certificate
You may have multiple firewalls to deal with. (AWS and UFW).
All firewalls must allow port 80 and 443.
I also can’t reach your site via port 80:
wget cloud5.dekk.io
–2019-01-24 21:58:26-- http://cloud5.dekk.io/
Resolving cloud5.dekk.io (cloud5.dekk.io)… 54.149.66.237
Connecting to cloud5.dekk.io (cloud5.dekk.io)|54.149.66.237|:80… failed: Connection timed out.
Indeed, it was the AWS firewall. Thanks for the help.
