/etc/init.d/CommuniGate stop
letsencrypt certonly --renew -d mail.domain.ru
Failed authorization procedure. mail.domain.ru (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout during connect (likely firewall problem)
My web server is (include version): as web server we are using CommuniGate pro where 443 port is listening
The operating system my web server runs on is: Ubuntu server 16.04.3 LTS
I’m using a control panel to manage my site: no
P.S.
i’am already used this commands for successfully obtaining certificate
The Let’s Encrypt agent can obtain and install HTTPS/TLS/SSL certificates. By
default, it will attempt to use a webserver both for obtaining and installing
the cert. Major SUBCOMMANDS are:
(default) run Obtain & install a cert in your current webserver
certonly Obtain cert, but do not install it (aka “auth”)
install Install a previously obtained cert in a server
renew Renew previously obtained certs that are near expiry
revoke Revoke a previously obtained certificate
rollback Rollback server configuration changes made during install
config_changes Show changes made to server config during installation
plugins Display information about installed plugins
letsencrypt: error: unrecognized arguments: certificates
