Hello,
I've been trying to generate certificates for my school project but with no luck.
I've followed a tutorial on digitalocean and have used a combination of WSGI, gunicorn and Flask.
I'm sure port 80,443 are open (see below).
Status: active
To                         Action      From
Nginx HTTP                 ALLOW       Anywhere
Nginx Full                 ALLOW       Anywhere
80                         ALLOW       Anywhere
443                        ALLOW       Anywhere
443/tcp                    ALLOW       Anywhere
Nginx HTTP (v6)            ALLOW       Anywhere (v6)
Nginx Full (v6)            ALLOW       Anywhere (v6)
80 (v6)                    ALLOW       Anywhere (v6)
443 (v6)                   ALLOW       Anywhere (v6)
443/tcp (v6)               ALLOW       Anywhere (v6)
definitelynotfakepills.club
sudo certbot --nginx
1: definitelynotfakepills.club
2: www.definitelynotfakepills.club
Requesting a certificate for definitelynotfakepills.club and www.definitelynotfakepills.club
Domain: definitelynotfakepills.club
Type: connection
Detail: During secondary validation: Fetching http://definitelynotfakepills.club/.well-known/acme-challenge/gSkIfztZFit0ZyCsfEbNT4M7TUAvCXr6w7OTBlCygEA: Timeout during connect (likely firewall problem)
Domain: www.definitelynotfakepills.club
Type: connection
Detail: During secondary validation: Fetching http://www.definitelynotfakepills.club/.well-known/acme-challenge/ElY3T9x33sN74O1QKY1CNZqYvWJCsJHTWDwUr4L6-KQ: Timeout during connect (likely firewall problem)
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 20.04
i dont think i can go into root but i do have sudo
no
certbot 1.16.0
Thanks in advance.
Hi @darthtater,
Perhaps you also have set a policy in your DigitalOcean account to confirm that DigitalOcean should allow inbound connections on port 80?
The firewall policy you posted is from your own server, but there could also be a firewall in DigitalOcean's network (before connections even reach you) that needs to be configured as well.
This reminds me somehow of
http://www.shadyurl.com/create.php
as well as
https://verylegit.link/
Hello @schoen,
I've only followed a tutorial on DigitalOcean. i've purchased my domain name from namecheap.com and i dont see any options for inbound connections...
As for my what my site looks like, it's still in the very early stages due to the certificate generation delay.. :laughing: but yes it looks pretty sketchy if i do say so myself
If you're hosted with DigitalOcean, you should also have access to a DigitalOcean control panel. I would check there to see if there are any settings that allow or block inbound connections.
