Hi -- I've been pulling my hair out over here trying to enable https on my home server running nextcloud and piwigo using Apache (details at the bottom). The http site works, but when I run certbot
all I get is "Timeout during connect (likely firewall problem)". My firewall is ufw, and allows ports 80 and 443. I even tried disabling ufw completely and running certbot, but it didn't help.
My sites-enabled folder for Apache has two files: photos.marcevanstein.com.conf
, and cumulonimbus.marcevanstein.com.conf
. photos.marcevanstein.com.conf
looks like:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
ServerName photos.marcevanstein.com
ServerAlias www.photos.marcevanstein.com
ServerAdmin [redacted]
DocumentRoot /var/www/html/piwigo
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
AliasMatch /.well-known/acme-challenge/(.*)$ /var/lib/letsencrypt/http_challenges/$1
<directory /var/lib/letsencrypt/http_challenges>
AllowOverride None
Require all granted
</directory>
</VirtualHost>
The AliasMatch
part was an experiment to see if I could access something under /.well-known/acme-challenge
. I put a test file there (http://photos.marcevanstein.com/.well-known/acme-challenge/test), and it is accessible it seems.
looks similar, but without the AliasMatch part.
Anyway, I've been at this for several days, and I clearly just don't understand enough about how these things work to be able to figure it out on my own. Thanks in advance for any help you can provide!
REQUESTED DETAILS
My domain is: photos.marcevanstein.com
, www.photos.marcevanstein.com
,cumulonimbus.marcevanstein.com
, and www.cumulonimbus.marcevanstein.com
(none of them are working)
Requesting a certificate for cumulonimbus.marcevanstein.com and 3 more domains
http-01 challenge for cumulonimbus.marcevanstein.com
http-01 challenge for photos.marcevanstein.com
http-01 challenge for www.cumulonimbus.marcevanstein.com
http-01 challenge for www.photos.marcevanstein.com
Challenge failed for domain cumulonimbus.marcevanstein.com
Challenge failed for domain photos.marcevanstein.com
Challenge failed for domain www.cumulonimbus.marcevanstein.com
Challenge failed for domain www.photos.marcevanstein.com
Domain: cumulonimbus.marcevanstein.com
Type: connection
Detail: Fetching
http://cumulonimbus.marcevanstein.com/.well-known/acme-challenge/WKbW3iukK000shRb7L_ZrWl3XVIMYqDlI0hnwQN-ZJI:
Domain: photos.marcevanstein.com
Type: connection
Detail: Fetching
http://photos.marcevanstein.com/.well-known/acme-challenge/RhBJX6ZG_IfpKMVSGtPnVCZSHo-gSLbXfEoqm9uVVy8:
Domain: www.cumulonimbus.marcevanstein.com
Type: connection
Detail: Fetching
http://www.cumulonimbus.marcevanstein.com/.well-known/acme-challenge/kNzFZCKuzcSEiTejPC8SXkDUvxP92UpXvuYkI9H2gsk:
Domain: www.photos.marcevanstein.com
Type: connection
Detail: Fetching
http://www.photos.marcevanstein.com/.well-known/acme-challenge/RCWNA6hR0ZGfbl3PtkX405YqovXVSNWp1CjesKSrUaM:
My web server is (include version): Apache, running on a home server
The operating system my web server runs on is (include version): Ubuntu 20.04.2 LTS (GNU/Linux 5.4.0-73-generic x86_64)
My hosting provider, if applicable, is: Home server, although the DNS is managed through asmallorange
via cpanel.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): for setting up the DNS to point to the server, yes, but otherwise no
or certbot-auto --version
if you're using Certbot): certbot 1.15.0, installed via snap
