I’ve already tried a lot:
There is no firewall running.
Port forwarding for tcp-ports 80 und 443 is activated on my router.
I suspect two possible problems:
  1. I use a Speedport Pro from Telekom (Hybrid DSL + LTE).
  2. Strict configuration in .htaccess for Nextcloud.
  3. DynDNS-Problems. I use dynv6. There is only a AAAA-record.
guckuck.dynv6.net
certbot renew
Processing /etc/letsencrypt/renewal/guckuck.dynv6.net.conf
http-01 challenge for guckuck.dynv6.net
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Challenge failed for domain guckuck.dynv6.net
Attempting to renew cert (guckuck.dynv6.net) from /etc/letsencrypt/renewal/guckuck.dynv6.net.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/guckuck.dynv6.net/fullchain.pem (failure)
    Domain: guckuck.dynv6.net
    Type: connection
    Detail: Fetching
    http://guckuck.dynv6.net/.well-known/acme-challenge/Csg6ZeTSZHyHP9a9wi1i2jaJHTXfceeA-56NsmlT80k:
nginx/1.18.0
PRETTY_NAME=“Debian GNU/Linux bullseye/sid”
NAME=“Debian GNU/Linux”
no
certbot 1.6.0
Hi @guckuck
there is a check of your domain, ~~45 minutes old - https://check-your-website.server-daten.de/?q=guckuck.dynv6.net
There you see the problem.
http://guckuck.dynv6.net/ 93.253.5.35 301 https://guckuck.dynv6.net/ Html is minified: 109,03 % 0.080 A
http://guckuck.dynv6.net/ 2003:cc:3f19:697f:b827:f524:e043:e7d4 -14 10.024 T
Timeout - The operation has timed out
Ipv4 answers, but ipv6 has a timeout.
Checking your domain Letsencrypt prefers ipv6, so that's critical.
  • Fix your ipv6 (or)
  • remove the ipv6 AAAA record
PS: Using my webserver I can trace my current local ipv6:
tracert 2003:e9:efff:2c98:f2b0:14ff:fe0e:fe30
The same with your address - no answer:
D:\temp>tracert 2003:cc:3f19:697f:b827:f524:e043:e7d4
Routenverfolgung zu p200300cc3f19697fb827f524e043e7d4.dip0.t-ipconnect.de [2003:cc:3f19:697f:b827:f524:e043:e7d4]
über maximal 30 Hops:
1 1 ms <1 ms <1 ms fritz.box [2003:e9:ef2c:8c00:f2b0:14ff:fe0e:fe2c]
2 5 ms 18 ms 4 ms 2003:0:8003:9800::1
3 7 ms 7 ms 7 ms 2003:0:8000:d000::1
4 35 ms 33 ms 33 ms p2003000643cb1700fa084ffffe8ad1eb.dip0.t-ipconnect.de [2003:6:43cb:1700:fa08:4fff:fe8a:d1eb]
5 * * * Zeitüberschreitung der Anforderung.
6 * * * Zeitüberschreitung der Anforderung.
7 * * * Zeitüberschreitung der Anforderung.
Thank you for your very fast response.
After searching since hours I think I have found the problem: The telekom-router (Speedport Pro) won’t allow ipv6 traffic from external to internal. And it seams to be not possible to deactive ipv6.
I deleted the AAAA-Record at the dyndns-provider. I also deactivated ipv6 on my Raspberry Pi.
But it is not possible to renew the certificate. Now I get the following error:
There
is your error. Change that.
Can you give me another hint? Please. :slight_smile:
So, I did it.
In den Config for my Nextcloud I added the following lines:
/etc/nginx/sites-available/default
location ~ ^/.well-known/acme-challenge/* {
        allow all;
Thanks for your help.
