From 2022/02/21 11:30 we have sometimes see problems, like those:
2022/02/21 14:01:07 Domain verification results for 'panda-zoomarket.ru': error. Fetching http://panda-zoomarket.ru/.well-known/acme-challenge/E0rlWCpjbN_Sh2KsvN-o0W-7G5mT3T6Xhpbw_FX--s0: Timeout during connect (likely firewall problem)
2022/02/21 14:01:25 Domain verification results for 'panda-zoomarket.ru': error. Fetching http://panda-zoomarket.ru/.well-known/acme-challenge/4ogdGoXs_SaF9EC6vPmEZZAQ8GmDt1p7PTKE7at_J8A: Timeout during connect (likely firewall problem)
2022/02/21 14:03:23 Domain verification results for 'parfumlandia.ru': error. Fetching http://parfumlandia.ru/.well-known/acme-challenge/taarU6M-J_dbR1XNJCP-OvBqP7MpiWQPqkjIekOLYAM: Timeout during connect (likely firewall problem)
2022/02/21 14:03:43 Domain verification results for 'parfumlandia.ru': error. Fetching http://parfumlandia.ru/.well-known/acme-challenge/yGQtKTxDHwowQuklyxXkNN24AsUbzYr4Hd_IzfRaMMk: Timeout during connect (likely firewall problem)
2022/02/21 14:05:32 Domain verification results for 'www.torsim.com': error. Fetching http://www.torsim.com/.well-known/acme-challenge/qqzXd6fOWmnLeU6tpYPDrek1lj2-VSFkXZSdsDbfxqg: Timeout during connect (likely firewall problem)
2022/02/21 14:06:16 Domain verification results for 'unicaero.ru': error. Fetching http://unicaero.ru/.well-known/acme-challenge/jXH4j6LmxJo0P-aG9wzb7tHqBOMlSEpjhgag9xlBMa0: Timeout during connect (likely firewall problem)
2022/02/21 14:09:25 Domain verification results for 'tomsk-realty.ru': error. Fetching http://tomsk-realty.ru/.well-known/acme-challenge/4ugsvnjNaLh9Pvcv2adjmlHwDY6iYKYvK8TxLs8Pudk: Timeout during connect (likely firewall problem)
2022/02/21 14:09:38 Domain verification results for 'www.tomsk-realty.ru': error. Fetching http://www.tomsk-realty.ru/.well-known/acme-challenge/7wQVnYDBzLDROSsROLqBxyo_N-bcDURaZBdWygeBb0U: Timeout during connect (likely firewall problem)
2022/02/21 14:09:55 Domain verification results for 'tomsk-realty.ru': error. Fetching http://tomsk-realty.ru/.well-known/acme-challenge/Pjqvn-Cmu6TZGiuRid2MbIYhHTBQKAfaI0qrfFdo7do: Timeout during connect (likely firewall problem)
2022/02/21 14:36:32 Domain verification results for 'мы-везём.рф': error. Fetching http://мы-везём.рф/.well-known/acme-challenge/q9cafFjrqIYmXpnLLaFqcpIjUg7S59QMmQkp3_v522M: Timeout during connect (likely firewall problem)
2022/02/21 14:51:29 Domain verification results for 'www.optom-voda.ru': error. Fetching http://www.optom-voda.ru/.well-known/acme-challenge/3SG0TnR7EVaZGmt5Dhncl0-O2H3TuXWeFdUUrwYg-Y4: Timeout during connect (likely firewall problem)
2022/02/21 15:00:26 Domain verification results for 'www.gkmcards.ru': error. Fetching http://www.gkmcards.ru/.well-known/acme-challenge/VTFqfq_z4MRlprGYWv0WlXWq1UoSXx81hvkfuFANJwU: Timeout during connect (likely firewall problem)
2022/02/21 15:18:31 Domain verification results for 'www.dobrayauborka.ru': error. Fetching http://www.dobrayauborka.ru/.well-known/acme-challenge/5K-aCAgOxnjDRZIBWesDorwgUMAilwYOe7aJNVI_pto: Timeout during connect (likely firewall problem)
2022/02/21 15:33:21 Domain verification results for 'idalgo.net': error. Fetching http://idalgo.net/.well-known/acme-challenge/XOhi8963tSZFzmlhUqKn6MrgBw405UQQJJp3-BgWcqM: Timeout during connect (likely firewall problem)
2022/02/21 15:33:32 Domain verification results for 'www.idalgo.net': error. Fetching Âåá ñòóäèÿ «IDALGO» | Cîçäàíèå ñàéòîâ â Íîâîðîññèéñêå, Àíàïå, Ãåëåíäæèêå: äèçàéí ñàéòà, ïîääåðæêà è ðàçìåùåíèå â èíòåðíåò. Timeout during connect (likely firewall problem)
2022/02/21 15:33:51 Domain verification results for 'idalgo.net': error. Fetching http://idalgo.net/.well-known/acme-challenge/cywHyD0RhrSUCFg94q5CTkAju4p-GPulJpUaT90QKvI: Timeout during connect (likely firewall problem)
2022/02/21 15:36:28 Domain verification results for 'ujniimf.ru': error. Fetching http://ujniimf.ru/.well-known/acme-challenge/dJwnYftxp7FjQLxjFIyDIhlaYj6vbG4gx76Ukp-iIiQ: Timeout during connect (likely firewall problem)
2022/02/21 15:39:21 Domain verification results for 'zakaz.rus-st.ru': error. Fetching http://zakaz.rus-st.ru/.well-known/acme-challenge/hZmL7nkuQzKjcWktxaKrVCGxMX-VrCtH_xi1D6E-h1g: Timeout during connect (likely firewall problem)
indeed. is your firewall filtering incoming connections based on geography or subnet?
Thanks, problem with global connectivity, from russian, we also have problems with availability ea and battlefield resources
I understand.
But this is not a problem of you reaching Let's Encrypt, it's the reverse: Let's Encrypt cannot reach you.
You can keep trying to run certbot renew --dry-run
and see if anything changes. When you see it working, remove --dry-run
(be careful, there is a rate limit on failed validations and it's pretty low, at 5/hour)
now there is no problem.,Last error was at 15:39, connectivity between segments restored. Thanks
