Third level domain: example.edu.do
I have registered a domain name infolex.edu.do and I am hosting it with Ipower. Ipower has Let’s Encrypt SSl y its Cpannel, but they do not support Let’s Encrypt SSl for third level domain. How can I solve that issue?
You need to speak with your provider - they need to fix their cPanel setting/restriction.
[or get a new provider]
LE has no such restriction.
I don't think that iPOWER use cPanel as in "cPanel Inc.". From what I've read, it's a custom control panel.
What did they actually say?
They said: I have checked it . Unfortunately FREE SSL is not supported for edu.do second level Extension domain names
Sorry , We offer POSITIVE ssl at 39.99$ per year and 71.99$ for 2 years
WILD CARD SSL 119.99$ per year and 215.98 for 2 years
You can check detailed features and pricing details of those ssl at https://shop.ipower.com/ssl-certificate
May i know if you would like to enable POSITIVE ssl or wild SSL on edu.do domain?
There’s no technical reason that they can’t do it, as @rg305 already suggested. Let’s Encrypt is not stopping you - iPOWER is.
From your perspective, I think the solution is probably to find another host without this restriction. Avoiding any of the EIG hosting brands is probably a good start.
I think you are very right. What does EIG mean?
@Radhamex That’s Endurance International Group. They’re based in Massachusetts, USA, but moved their IT infrastructure to India. They had bought out a lot of small companies. That’s how they got so big. :roll_eyes:
