I've moved your thread to the #help section, as I'm thinking your thread is more about getting help with issuance than you'd like to discuss something about issuance.
In the #help section, you would have been provided with a questionnaire, which is mandatory to fill out to get proper support. While you've already given us some answers, I'd like to invite you to answer all the questions nonetheless as good as you can. If you don't know the answer to a question directly, please say so in stead of leaving it blank. Here's the questionnaire:
This is probably the important part. Whichever ACME client you are using is trying to use DNS validation (updating your domain's DNS with an _acme-challenge TXT record to prove you control that domain). You need to look at how that is configured and that will depend on what tool you are using to get certificates.
This error means that the cPanel account in question does not have the right permissions to be able to modify their own DNS records.
If you're the admin of the VPS, you can fix this:
Make sure that the Zone Editor (AAAA, CAA, SRV, TXT) feature is enabled WHM Feature Manager for each package that you want to be able to use DNS validation.
Remember also that the domain needs to be using the cPanel nameservers, not external ones.
It there any way how I can check the really cause of this issue? I'm desperate in this case, can't get it resolved.. Has Let's Encrypt a paid service to get this solved?
