There is no Security section or a SSL/TLS icon in my Control Panel
I’ve created a Let’s Encrypt certificate and my instructions say to add the certificate via Control Panel’s SSL/TLS icon in the Security section. However there is no Security section or a SSL/TLS icon in my Control Panel
I have the Deluxe Web Hosting Linux plan in Godaddy without security section
Is there a way to setup LetsEncrypt SSL without SSL/TLS step?
Hi @Remondo
you must be able to install the certificate. If your Cotrol panel doesn't allow that (and if you don't have root access), it may be impossible.
I don't know that plan.
  • You didn't found it, perhaps share a screenshot
  • The option may not exist -> ask GoDaddy
GoDaddy says that this feature not available in my old host plan !
Then that’s your problem. You may want to consider migrating to a less user-hostile hosting provider.
