seraj
July 20, 2019, 10:34pm
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: https://www.emctechnologie.com/
I ran this command: /opt/letsencrypt/letsencrypt-auto --apache -d www.emctechnologie.com -d emctechnologie.com
but the lock does not activate for the SSL
Hi @seraj
your certificate is correct. But you have some mixed conent you should fix. See https://check-your-website.server-daten.de/?q=emctechnologie.com
The certificate is good:
CN=www.emctechnologie.com
12.07.2019
10.10.2019
expires in 81 days
emctechnologie.com, www.emctechnologie.com - 2 entries
you have three redirects and one preferred version, that's good.
But a Grade I isn't good -> mixed content.
7 images, 2 style attributes.
Sample:
http://www.emctechnologie.com/wp-content/uploads/2019/01/DevInfo.jpg
http://54.77.141.122/wp-content/uploads/2019/01/phone.png
change these to https. And don't use ip addresses.
The two style attributes have ip addresses + https, that can't work.
system
Closed
August 19, 2019, 10:52pm
3
