Hi @Compstuff
here is the Synology guide:
Here is the cloudflare usage:
@Neilpang I am feeling pretty ignorant because of my lack of linux command line knowledge but I must have syntax wrong because I am trying the following and they all give me a crontab install error:
curl https://get.acme.sh | sh --force
curl https://get.acme.sh | sh --install --force
curl https://get.acme.sh | sh --FORCE
so I did it manually
$ wget https://github.com/Neilpang/acme.sh/archive/master.tar.gz
$ tar xvf master.tar.gz
$ cd acme.sh-master/
$ ./acme.sh --install --nocron
install is done
@Neilpang, @serverco I added the two variables CF_Key="" & CF_Email="" to account.conf and then ran:
./acme.sh --issue -d EXAMPLE.COM --dns dns_cf --certpath /usr/syno/etc/ssl/ssl.crt/server.crt --keypath /usr/syno/etc/ssl/ssl.key/server.key --fullchainpath /usr/syno/etc/ssl/ssl.intercrt/server-ca.crt --debug
which fails and gives me:
invalid domain
Error add txt for domain:_acme-challenge.EXAMPLE.COM
invalid_domain_error.txt (4.9 KB)
Please add --debug 2
to output more details:
It looks as if there was an issue with adding the token to your domain. Itād always slightly more tricky when you change your domain name to example.com in the file though to see what is going on. Your domain name is public anyway ( and can be determined from the file) @Neilpang is the author of acme.sh so best to help debug that with you.
understoodā¦ I wasnāt sure what to remove other than my CF infoā¦ attached with real name
invalid_domain_error_level2-with-name.txt (13.2 KB)
I think I updated the code properly and ran againā¦ same error attached latest debug
invalid_domain_error_level2-with-name-NEW-CODE.txt (13.3 KB)
AWESOME!!! IT WORKED THANK YOU VERY MUCH!!!
