Synology - Cannot issue a certificate mittra.me or books.mittra.me
My domain is: mittra.me
I ran this command: Add a new certificate >> Get a certificate from lets encrypt >>
It produced this output:The operation failed. Please log into DSM and retry.
My web server is (include version):nginx
The operating system my web server runs on is (include version): Synology DSM 6.2
My hosting provider, if applicable, is: namecheap
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): NA
Have you updated to the latest firmware?
Yes, It is the latest firmware.
It is difficult to be certain, but the HTTP response on a simple challenge request test appears to require authentication.
If so, this will break the LE challenge.
curl -Iki http://mittra.me/.well-known/acme-challenge/test-file
HTTP/1.1 403 Forbidden
Date: Sat, 16 May 2020 10:37:54 GMT
Content-Type: text/html
Content-Length: 11939
Keep-Alive: timeout=20
Vary: Accept-Encoding
ETag: "5aff6d93-2ea3"
Lets debug results show everything is okay?
Are you able to place a test-file in that challenge location?
Hi @nmittra
checking
http://mittra.me/.well-known/acme-challenge/1234
there is a
© 2018 Synology Inc.
Checking the table from "check your website" with the html content reduced, the newest checks: There are some
© 2019 Synology Inc.
So: Is your firmware really up to date? Doesn't look so.
