Will work “normal” certificates obtained for the domains one.example.com, two.example.com after i get the wildcard certificate for *.example.com?
Will the certificate be valid for example.com if i get a new certificate for it on another server?
Are there any restrictions?
If you suddenly need: now I use certbot, and will use acme.sh later
Thanks
Let’s Encrypt doesn’t automatically revoke your old certificates when you issue new certificates.
Certbot doesn’t either.
As far as I know, acme.sh doesn’t.
You could manually revoke your certificates if you want to, but you don’t need to, unless the private key has been compromised, or you no longer control the domain.
Thanks for the quick response! I just want to know if the “old” certificates will work after I get the wildcard and start distributing it
They won’t be automatically revoked. They won’t stop working for any other reason.
