I have been doing some digging to find a solution and it’s not playing out to be very clear. I set up a VPS and had LE working then switched to Cloudflare CDN. Now cert renewal fails for LE. It seems because I did a nginx install of the certs is the issue. Am I correct that I need to switch to webroot? If so what are the steps to switch? It just isn’t very clear as to how I go about switching.
Thanks in advance for any questions, comments, or smart remarks
