I successfully updated my certificates three months ago by using sudo certbot for all my domains. Now, 3+ months later, it’s time to renew. When running sudo certbot I get references to Disney, as per below. Why?
sudo certbot
Certificate did not match expected hostname: acme-v02.api.letsencrypt.org. Certificate: {‘subject’: (((‘commonName’, ‘disneycruise.disney.go.com’),),), ‘subjectAltName’: [(‘DNS’, ‘disneycruise.disney.go.com’), (‘DNS’, ‘www.disneycruiselinetravel.com’), (‘DNS’, ‘www.disneycruiselatino.com’), (‘DNS’, ‘www.disneycruisebrasil.com’)]}
An unexpected error occurred:
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 350, in _make_request
self._validate_conn(conn)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 837, in _validate_conn
conn.connect()
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 339, in connect
_match_hostname(cert, self.assert_hostname or hostname)
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 349, in _match_hostname
match_hostname(cert, asserted_hostname)
File “/usr/lib/python3.5/ssl.py”, line 305, in match_hostname
% (hostname, ', '.join(map(repr, dnsnames))))
ssl.CertificateError: hostname ‘acme-v02.api.letsencrypt.org’ doesn’t match either of ‘disneycruise.disney.go.com’, ‘www.disneycruiselinetravel.com’, ‘www.disneycruiselatino.com’, ‘www.disneycruisebrasil.com’
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 423, in send
timeout=timeout
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 624, in urlopen
raise SSLError(e)
requests.packages.urllib3.exceptions.SSLError: hostname ‘acme-v02.api.letsencrypt.org’ doesn’t match either of ‘disneycruise.disney.go.com’, ‘www.disneycruiselinetravel.com’, ‘www.disneycruiselatino.com’, ‘www.disneycruisebrasil.com’
requests.exceptions.SSLError: hostname ‘acme-v02.api.letsencrypt.org’ doesn’t match either of ‘disneycruise.disney.go.com’, ‘www.disneycruiselinetravel.com’, ‘www.disneycruiselatino.com’,
Server version: Apache/2.4.25 (Debian)
Server built: 2019-10-13T15:43:54
Debian GNU/Linux 9 (stretch)
no
or certbot-auto --version
if you’re using Certbot):
0.28.0
