FYI: I was able to fix the last two errors renewing www subdomains only doing this steps:
- renaming .htaccess to .htaccess_tmp
- renew base domain and www subdomain as usual
- renaming .htaccess_tmp to .htaccess
What's inside that .htaccess?
Nothing strange (I think) ...
# cat .htaccess
# BEGIN WordPress
# Las directivas (líneas) entre `BEGIN WordPress` y `END WordPress` se generan dinámicamente
# , y solo se deberían modificar mediante filtros de WordPress.
# Cualquier cambio en las directivas que hay entre esos marcadores se sobreescribirán.
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
Sorry (I'm not the site developer), I thought both domains had the same content in the file (two wordpress sites), but no.
The other one it's a little bit more complex, but nothing strange for me too ...
# BEGIN WordPress
# Les directives (línies) entre "BEGIN WordPress" i "END WordPress" es generen dinàmicament i haurien de ser solament modificades mitjançant els filtres del WordPress.
# Qualsevol canvi entre aquestes marques se sobreescriuran.
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
</IfModule>
# END WordPress
# BEGIN HTML5 Boilerplate
# Les directives (línies) entre `BEGIN HTML5 Boilerplate` i `END HTML5 Boilerplate` es generen dinàmicament i haurien de ser solament modificades mitjançant els filtres del WordPress.
<IfModule mod_setenvif.c>
<IfModule mod_headers.c>
<FilesMatch "\.(bmp|cur|gif|ico|jpe?g|png|svgz?|webp)$">
SetEnvIf Origin ":" IS_CORS
Header set Access-Control-Allow-Origin "*" env=IS_CORS
</FilesMatch>
</IfModule>
</IfModule>
<FilesMatch "\.(eot|otf|tt[cf]|woff2?)$">
</FilesMatch>
</IfModule>
Header set X-UA-Compatible "IE=edge"
# `mod_headers` cannot match based on the content-type, however,
# the `X-UA-Compatible` response header should be send only for
# HTML documents and not for the other resources.
<FilesMatch "\.(appcache|atom|bbaw|bmp|crx|css|cur|eot|f4[abpv]|flv|geojson|gif|htc|ico|jpe?g|js|json(ld)?|m4[av]|manifest|map|mp4|oex|og[agv]|opus|otf|pdf|png|rdf|rss|safariextz|svgz?|swf|topojson|tt[cf]|txt|vcard|vcf|vtt|webapp|web[mp]|webmanifest|woff2?|xloc|xml|xpi)$">
Header unset X-UA-Compatible
</FilesMatch>
</IfModule>
<IfModule mod_mime.c>
# Data interchange
AddType application/atom+xml atom
AddType application/json json map topojson
AddType application/ld+json jsonld
AddType application/rss+xml rss
AddType application/vnd.geo+json geojson
AddType application/xml rdf xml
# JavaScript
# Normalize to standard type.
# https://tools.ietf.org/html/rfc4329#section-7.2
AddType application/javascript js
# Manifest files
AddType application/manifest+json webmanifest
AddType application/x-web-app-manifest+json webapp
AddType text/cache-manifest appcache
# Media files
AddType audio/mp4 f4a f4b m4a
AddType audio/ogg oga ogg opus
AddType image/bmp bmp
AddType image/svg+xml svg svgz
AddType image/webp webp
AddType video/mp4 f4v f4p m4v mp4
AddType video/ogg ogv
AddType video/webm webm
AddType video/x-flv flv
# Serving `.ico` image files with a different media type
# prevents Internet Explorer from displaying then as images:
# https://github.com/h5bp/html5-boilerplate/commit/37b5fec090d00f38de64b591bcddcb205aadf8ee
AddType image/x-icon cur ico
# Web fonts
AddType application/font-woff woff
AddType application/font-woff2 woff2
AddType application/vnd.ms-fontobject eot
# Browsers usually ignore the font media types and simply sniff
# the bytes to figure out the font type.
# https://mimesniff.spec.whatwg.org/#matching-a-font-type-pattern
# However, Blink and WebKit based browsers will show a warning
# in the console if the following font types are served with any
# other media types.
AddType application/x-font-ttf ttc ttf
AddType font/opentype otf
# Other
AddType application/octet-stream safariextz
AddType application/x-bb-appworld bbaw
AddType application/x-chrome-extension crx
AddType application/x-opera-extension oex
AddType application/x-xpinstall xpi
AddType text/vcard vcard vcf
AddType text/vnd.rim.location.xloc xloc
AddType text/vtt vtt
AddType text/x-component htc
</IfModule>
AddDefaultCharset utf-8
AddCharset utf-8 .atom \
.bbaw \
.css \
.geojson \
.js \
.json \
.jsonld \
.manifest \
.rdf \
.rss \
.topojson \
.vtt \
.webapp \
.webmanifest \
.xloc \
.xml
</IfModule>
# (1)
RewriteEngine On
# (2)
# Options +FollowSymlinks
# (3)
# Options +SymLinksIfOwnerMatch
# (4)
# RewriteBase /
# (5)
# RewriteOptions <options>
# (6)
RewriteCond %{HTTPS} =on
RewriteRule ^ - [env=proto:https]
RewriteCond %{HTTPS} !=on
RewriteRule ^ - [env=proto:http]
</IfModule>
<IfModule mod_autoindex.c>
Options -Indexes
</IfModule>
RewriteEngine On
RewriteCond %{REQUEST_URI} "!(^|/)\.well-known/([^./]+./?)+$" [NC]
RewriteCond %{SCRIPT_FILENAME} -d [OR]
RewriteCond %{SCRIPT_FILENAME} -f
RewriteRule "(^|/)\." - [F]
</IfModule>
<FilesMatch "(^#.*#|\.(bak|conf|dist|fla|in[ci]|log|psd|sh|sql|sw[op])|~)$">
# Apache < 2.3
<IfModule !mod_authz_core.c>
Order allow,deny
Deny from all
Satisfy All
</IfModule>
# Apache ≥ 2.3
<IfModule mod_authz_core.c>
Require all denied
</IfModule>
</FilesMatch>
Header set X-Content-Type-Options "nosniff"
</IfModule>
Header unset X-Powered-By
</IfModule>
ServerSignature Off
<IfModule mod_deflate.c>
# Force compression for mangled `Accept-Encoding` request headers
# https://developer.yahoo.com/blogs/ydn/pushing-beyond-gzipping-25601.html
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Compress all output labeled with one of the following media types.
# (!) For Apache versions below version 2.3.7 you don't need to
# enable `mod_filter` and can remove the `<IfModule mod_filter.c>`
# and `</IfModule>` lines as `AddOutputFilterByType` is still in
# the core directives.
# https://httpd.apache.org/docs/current/mod/mod_filter.html#addoutputfilterbytype
AddOutputFilterByType DEFLATE "application/atom+xml" \
"application/javascript" \
"application/json" \
"application/ld+json" \
"application/manifest+json" \
"application/rdf+xml" \
"application/rss+xml" \
"application/schema+json" \
"application/vnd.geo+json" \
"application/vnd.ms-fontobject" \
"application/x-font-ttf" \
"application/x-javascript" \
"application/x-web-app-manifest+json" \
"application/xhtml+xml" \
"application/xml" \
"font/eot" \
"font/opentype" \
"image/bmp" \
"image/svg+xml" \
"image/vnd.microsoft.icon" \
"image/x-icon" \
"text/cache-manifest" \
"text/css" \
"text/html" \
"text/javascript" \
"text/plain" \
"text/vcard" \
"text/vnd.rim.location.xloc" \
"text/vtt" \
"text/x-component" \
"text/x-cross-domain-policy" \
"text/xml"
</IfModule>
# Map the following filename extensions to the specified
# encoding type in order to make Apache serve the file types
# with the appropriate `Content-Encoding` response header
# (do note that this will NOT make Apache compress them!).
# If these files types would be served without an appropriate
# `Content-Enable` response header, client applications (e.g.:
# browsers) wouldn't know that they first need to uncompress
# the response, and thus, wouldn't be able to understand the
# content.
# https://httpd.apache.org/docs/current/mod/mod_mime.html#addencoding
AddEncoding gzip svgz
</IfModule>
</IfModule>
Header unset ETag
</IfModule>
FileETag None
<IfModule mod_expires.c>
ExpiresActive on
ExpiresDefault "access plus 1 month"
# CSS
ExpiresByType text/css "access plus 1 year"
# Data interchange
ExpiresByType application/atom+xml "access plus 1 hour"
ExpiresByType application/rdf+xml "access plus 1 hour"
ExpiresByType application/rss+xml "access plus 1 hour"
ExpiresByType application/json "access plus 0 seconds"
ExpiresByType application/ld+json "access plus 0 seconds"
ExpiresByType application/schema+json "access plus 0 seconds"
ExpiresByType application/vnd.geo+json "access plus 0 seconds"
ExpiresByType application/xml "access plus 0 seconds"
ExpiresByType text/xml "access plus 0 seconds"
# Favicon (cannot be renamed!) and cursor images
ExpiresByType image/vnd.microsoft.icon "access plus 1 week"
ExpiresByType image/x-icon "access plus 1 week"
# HTML
ExpiresByType text/html "access plus 0 seconds"
# JavaScript
ExpiresByType application/javascript "access plus 1 year"
ExpiresByType application/x-javascript "access plus 1 year"
ExpiresByType text/javascript "access plus 1 year"
# Manifest files
ExpiresByType application/manifest+json "access plus 1 week"
ExpiresByType application/x-web-app-manifest+json "access plus 0 seconds"
ExpiresByType text/cache-manifest "access plus 0 seconds"
# Media files
ExpiresByType audio/ogg "access plus 1 month"
ExpiresByType image/bmp "access plus 1 month"
ExpiresByType image/gif "access plus 1 month"
ExpiresByType image/jpeg "access plus 1 month"
ExpiresByType image/png "access plus 1 month"
ExpiresByType image/svg+xml "access plus 1 month"
ExpiresByType image/webp "access plus 1 month"
ExpiresByType video/mp4 "access plus 1 month"
ExpiresByType video/ogg "access plus 1 month"
ExpiresByType video/webm "access plus 1 month"
# Web fonts
# Embedded OpenType (EOT)
ExpiresByType application/vnd.ms-fontobject "access plus 1 month"
ExpiresByType font/eot "access plus 1 month"
# OpenType
ExpiresByType font/opentype "access plus 1 month"
# TrueType
ExpiresByType application/x-font-ttf "access plus 1 month"
# Web Open Font Format (WOFF) 1.0
ExpiresByType application/font-woff "access plus 1 month"
ExpiresByType application/x-font-woff "access plus 1 month"
ExpiresByType font/woff "access plus 1 month"
# Web Open Font Format (WOFF) 2.0
ExpiresByType application/font-woff2 "access plus 1 month"
# Other
ExpiresByType text/x-cross-domain-policy "access plus 1 week"
</IfModule>
RewriteRule ^wp-admin/includes/ - [F,L]
RewriteRule !^wp-includes/ - [S=3]
RewriteRule ^wp-includes/js/tinymce/langs/.+\.php - [F,L]
RewriteRule ^wp-includes/theme-compat/ - [F,L]
RewriteCond %{SCRIPT_FILENAME} !^(.*)wp-includes/ms-files.php
RewriteRule ^wp-includes/[^/]+\.php$ - [F,L]
</IfModule>
<FilesMatch "^(wp-config\.php|readme\.html|license\.txt|install\.php)">
# Apache < 2.3
Order allow,deny
Deny from all
Satisfy All
</IfModule>
# Apache ≥ 2.3
Require all denied
</IfModule>
</FilesMatch>
# END HTML5 Boilerplate
I am not even sure what this is supposed to do.
Do either of the two files "work"?
Nothing new here.
I only had one affected server and was finally able to renew the certificate. But obviously, it was luck. I'm dreading the rest of the renewals.
Oh! I missed this part. I don't know what does. As I said I'm not the web developer. Seems it's auto generated by some wordpress theme or plugin (# BEGIN HTML5 Boilerplate)
Domain one has the first .htaccess
Domain two has the second .htaccess
The same error occurs on both domains
The error has solved (bypassed) for both domains with the same procedure...
Today, another domain with the same error, has solved as decribed in my last post.
The .htaccess ...
# BEGIN WordPress
# The directives (lines) between "BEGIN WordPress" and "END WordPress" are
# dynamically generated, and should only be modified via WordPress filters.
# Any changes to the directives between these markers will be overwritten.
RewriteEngine On
RewriteBase /
</IfModule>
Clearly the .htaccess files are not working as intended.
The one with:
Seems to have come closest (because it at least acknowledged the need to handle the challenge folder), but also fails because it includes multiple sections all dealing with redirections individually and incorrectly.
Forget the .htaccess with
Is what worries me the least
All other .htaccess files does not have a similar line and fails to renew www subdomain
All files fail.
All .htaccess files are bad.
Sorry, but I can't understand you ... Why all .htaccess files are bad?
Because they're a perfect road to an unpredictable mess where people don't even know where their config is.
(And we are used to having full control over the machine, so we like putting our config in /etc/apache2/sites-available/sitename.conf instead of random directories in htdocs.)
Ok, ok, I understand, you are referring to the concept
Yes.
Also: they're specific to Apache. It makes it a lot harder to switch to another webserver, should you want to.
But they have positive sides: on a shared hosting, you can use a .htaccess to hack your way to something, if the AllowOverride directive likes you.
Finally, an answer from my server provider (IONOS) ...
In relation to the problem reported with Let's Encrypt SSL certificates in Plesk, it has been verified that there is no restriction on our part, and that the problem would be on the side of Let's Encrypt and Plesk.
You can find information about the solution in the following articles:
Original...
En relación al problema reportado con los certificados SSL de Let's Encrypt en Plesk, se ha comprobado que no hay ninguna restricción por nuestra parte, y que el problema estaría del lado de Let's Encrypt y Plesk.
En los siguientes artículos puede encontrar información sobre la solución:
Suddenly Timeout during connect (likely firewall problem) for www subdomain - #25 by mserra
As you can see, they wash their hands and links to this forum ![]()
Yesterday I could renew without issues the SSL of around 1200 domains that were going to be expire in the next 30 days.
8 servers, same config, no changes.
Did anyone noticed something positive since yesterday?
Thank's Wolfix, and sorry for 2 days delay on answer.
After a few tests seems now it's working again.
As you, same config, no changes.
I'm sure IONOS has solved some connectivity issue.
