I have successfully set up certbot for mpark.uk
. This address points to a self-hosted URL shortener (YOURLS) that is hosted on Google Cloud Platform with the following configuration:
- Ubuntu: 20.04.2 LTS
- Nginx: 1.18.0
- Certbot: 1.13.0
- Snap: 2.49.1
Cloud DNS configuration on GCP
DNS name | Type | TTL | Data |
mpark.uk. | A | 300 | Static IP of server |
mpark.uk. | SOA | 21600 | ns-cloud-a1.googledomains.com. cloud-dns-hostmaster.google.com. 1 21600 3600 259200 300 |
mpark.uk. | NS | 21600 | ns-cloud-a1.googledomains.com. ns-cloud-a2.googledomains.com. ns-cloud-a3.googledomains.com. ns-cloud-a4.googledomains.com. |
wiki.mpark.uk. | CNAME | 300 | mrmpark.github.io. |
www.mpark.uk. | CNAME | 300 | mpark.uk. |
Nginx configuration for YOURLS
$ cat /etc/nginx/sites-enabled/yourls.conf
server_name mpark.uk;
root /var/www/html/YOURLS;
index index.php index.html index.htm;
try_files $uri $uri/ /yourls-loader.php$is_args$args;
location ~ \.php$ {
try_files $uri =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
include fastcgi_params;
ssl_certificate /etc/letsencrypt/live/mpark.uk/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mpark.uk/privkey.pem; # managed by Certbot
if ($host = mpark.uk) {
} # managed by Certbot
listen 80;
I made the assumption that the subdomains would be secured as part of the set up process for the main domain, but when I checked whether the subdomains were secured, I realised that this is not the case. I then attempted to add the wiki
& www
subdomains as follows:
$ sudo certbot certonly –standalone -d mpark.uk -d www.mpark.uk -d wiki.mpark.uk`
requested (ref: /etc/letsencrypt/renewal/mpark.uk.conf)
It contains these names: mpark.uk
You requested these names for the new certificate: mpark.uk, www.mpark.uk,
wiki.mpark.uk.
certificate?
(E)xpand/(C)ancel: e
Renewing an existing certificate for mpark.uk and 2 more domains
http-01 challenge for wiki.mpark.uk
http-01 challenge for www.mpark.uk
Problem binding to port 80: Could not bind to IPv4 or IPv6.
I then tried to stop Nginx, run the above command again and then restart, which produced the same result. I am not sure if the problem is caused by an incorrect Nginx / certbot configuration or something else. Any assistance to help get this working would be much appreciated.
Kind regards,
Mike
