Thanks I will try it now and let you know .
sorry, it did not worked
listen 80;
listen [::]:80;
root /var/www/vmeet.ca/html;
index index.html index.htm;
server_name vmeet.ca www.vmeet.ca;
if ($scheme=='http') {
try_files $uri $uri/ =404;
Then try it as two separate server sections (one for HTTP another for HTTPS):
listen 80;
listen [::]:80;
root /var/www/vmeet.biz/html;
server_name vmeet.biz www.vmeet.biz;
}#server
listen [::]:443 ssl; # managed by Certbot
}#location
ssl_certificate /etc/letsencrypt/live/www.vmeet.ca/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/www.vmeet.ca/privkey.pem; # managed by Certbot
}#server
did follow with your suggestion changing the config inside the server blocks but no changes from the browser end, I maintain the domain with .ca while your suggestion is on the .biz
Dude, I just modified what you posted.
Feel free to adjust it accordingly.
is that good or bad?
I donât understand the questionâŚ
sorry, just to responding to your last comment, either way, there is no changes from the browser end still not secured?
In case you need to know I restart the Nginx and purge all history from the web site browsing
I donât know your config.
You said you had a problem and showed some code.
I asked you to include some code but that failed to fix it.
So I modified the code you showed to separate the HTTP form the HTTPS in an attempt to fix your problem.
If that is NOT the code with the problem, then why did you post it?
#1: Your problem now has nothing to do with LE nor the certificate - it is entirely an NGINX coding problem
#2: If you canât figure how to use the example provided, then you probably shouldnât be coding in the first place.
I am not sure if it is the code or not, but in any case the Nginx is not listening the server block command, the LE certificate is registered but Nginx is not doing what it supposed to do, one other question from this:
I noticed the certificate is www.vmeet.ca/fullchain.pem
will that the same on all other domains? including .biz?
You can see which certs you have and which domains they cover with:
certbot certificates
root@conference:/home/michael# cerbot certificates
Command âcerbotâ not found, did you mean:
command âcertbotâ from deb certbot
Try: apt install
Not sure how this is happeningâŚ
Are you using two systems?
Your initial post said you had certbot and you claim to have a useable cert.
Please explain.
Yes I just installed the cert today and you see the certificate showed as it stated on the config file
I used the certbot site instruction installed the cert
and follow its instruction on certbot -i nginx -d domain -d www.domain etc
just check my response to you , there were typo on my part for the certbot but no âtâ
Yes, I see the typo now too.
Happens when I type too fast - lol
[went back and fixed it]
The cert name listed with domains included , does that conflict with what we are trying to do?
Certificate Name: vmeet.ca
Domains: vmeet.ca vmeet.biz
Expiry Date: 2020-09-11 19:48:11+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/vmeet.ca/fullchain.pem
Private Key Path: /etc/letsencrypt/live/vmeet.ca/privkey.pem
Certificate Name: www.vmeet.ca
Domains: www.vmeet.ca www.vmeet.biz
Expiry Date: 2020-09-11 20:26:37+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.vmeet.ca/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.vmeet.ca/privkey.pem
Oh, thatâs terrible.
The WWWâs are in a cert by themselves.
And the names are criss-crossedâŚ
It should be:
cert 1:
Domains: vmeet.ca www.vmeet.ca
cert 2:
Domains: vmeet.biz www.vmeet.biz
or just one cert with all four in it:
Domains: vmeet.ca www.vmeet.ca vmeet.biz www.vmeet.biz
OK, how to fix that do I need to reinstall the cert? Can I do a roll back on certbot rollback nginx -d vmeet.ca -d vmeet.biz -d www.vmeet.ca -d www.vmeet.biz and reinstall as you suggested?
You need to get a new cert (or two).
Then use them as needed.
