certbot certonly --help produces incomplete output.
Let me know how to get actual dump of all certonly flags… I know there are many, because I’m using many flags which are missing from help message.
Thanks.
Thanks.
certbot --help certonly
should give you the help for the certonly subcommand (note the order). Or you can use certbot --help all
for everything.
Perfect.
This gets me what I was after… The docs for no-hsts…
Thanks!
