Stopped being able to fetch certificate after long inactivity
upperlimit.net
certbot certonly (as root)
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel): upperlimit.net
Requesting a certificate for upperlimit.net
http-01 challenge for upperlimit.net
Challenge failed for domain upperlimit.net
   Domain: upperlimit.net
   Type:   connection
   Detail: 194.163.190.255: Fetching
   http://upperlimit.net/.well-known/acme-challenge/cnaLTZ6P2mgbfk-a9SvuMC-EGFq61cQOAxAPa-3R3ZM:
   Error getting validation data
None
CentOS 7
no
1.11.0
After repeatedly failing to get my certificate I am now locked out.
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
Please use the staging environment for testing to prevent this rate limit.
With regard to your issue: your entire website is down: from my point of view I cannot connect to your IP address on port 80 nor 443. I do see port 22 and 8443 being marked as "closed" by NMap, so it seems the host is up. Looks like all other ports, including 80 and 443, are being filtered by a firewall.
If you fix your general website connectivity issues, you probably also fix your certificate issuance issue.
Thanks.
I am not using a web server but I am using the certificate for some of my running applications on non-standard ports.
Therefore, it is expected for port 80 to be down.
I am using non-standard ports for all services.
Therefore, it is expected for ports 22 and 8443 to be marked as "closed".
However, it turns out that port 80 was not allowed in the firewall.
False alarm, I should have thought about it earlier.
It works now.
