2017-03-27 19:43:45,557:DEBUG:letsencrypt.cli:Root logging level set at 30
2017-03-27 19:43:45,558:INFO:letsencrypt.cli:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2017-03-27 19:43:45,559:DEBUG:letsencrypt.cli:letsencrypt version: 0.4.1
2017-03-27 19:43:45,559:DEBUG:letsencrypt.cli:Arguments: ['-a', 'webroot', '--webroot-path', '/myprojectdir/htdocs', '-d', 'www.mydomain.com', '-d', 'sk.mydomain.com', '-d', 'mydomain.com']
2017-03-27 19:43:45,559:DEBUG:letsencrypt.cli:Discovered plugins: PluginsRegistry(PluginEntryPoint#webroot,PluginEntryPoint#null,PluginEntryPoint#manual,PluginEntryPoint#standalone)
2017-03-27 19:43:45,563:DEBUG:letsencrypt.cli:Requested authenticator webroot and installer None
2017-03-27 19:43:45,564:DEBUG:letsencrypt.plugins.webroot:Creating root challenges validation dir at /myprojectdir/htdocs/.well-known/acme-challenge
2017-03-27 19:43:45,564:DEBUG:letsencrypt.display.ops:Single candidate plugin: * webroot
Description: Webroot Authenticator
Entry point: webroot = letsencrypt.plugins.webroot:Authenticator
Initialized: <letsencrypt.plugins.webroot.Authenticator object at 0x7f72693525d0>
Prep: True
2017-03-27 19:43:45,565:DEBUG:letsencrypt.cli:Selected authenticator <letsencrypt.plugins.webroot.Authenticator object at 0x7f72693525d0> and installer None
2017-03-27 19:44:04,330:DEBUG:root:Sending GET request to https://acme-v01.api.letsencrypt.org/directory. args: (), kwargs: {}
2017-03-27 19:44:04,399:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
2017-03-27 19:44:04,632:DEBUG:letsencrypt.cli:Exiting abnormally:
File "/usr/bin/letsencrypt", line 9, in <module>
load_entry_point('letsencrypt==0.4.1', 'console_scripts', 'letsencrypt')()
File "/usr/lib/python2.7/dist-packages/letsencrypt/cli.py", line 1986, in main
File "/usr/lib/python2.7/dist-packages/letsencrypt/cli.py", line 689, in obtain_cert
le_client = _init_le_client(config, authenticator, installer)
File "/usr/lib/python2.7/dist-packages/letsencrypt/cli.py", line 206, in _init_le_client
acc, acme = _determine_account(config)
File "/usr/lib/python2.7/dist-packages/letsencrypt/cli.py", line 191, in _determine_account
config, account_storage, tos_cb=_tos_cb)
File "/usr/lib/python2.7/dist-packages/letsencrypt/client.py", line 121, in register
acme = acme_from_config_key(config, key)
File "/usr/lib/python2.7/dist-packages/letsencrypt/client.py", line 46, in acme_from_config_key
return acme_client.Client(config.server, key=key, net=net)
File "/usr/lib/python2.7/dist-packages/acme/client.py", line 63, in __init__
self.net.get(directory).json())
File "/usr/lib/python2.7/dist-packages/acme/client.py", line 627, in get
self._send_request('GET', url, **kwargs), content_type=content_type)
File "/usr/lib/python2.7/dist-packages/acme/client.py", line 609, in _send_request
response = requests.request(method, url, *args, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 53, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 468, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 576, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/adapters.py", line 447, in send
raise SSLError(e, request=request)
SSLError: [X509] PEM lib (_ssl.c:2831)
