GoDaddy serves the short chain by default now. I need to test with the long chain.
i don't know how you got that info, because all i know about the certificate stuff is how to set it and redirect nevertheless i am a web developer but with freelance experience not corporate
that would not work, because i already set the certificate and it needs the key also
should i paste all 3 certificate that i get ? because i pasted the first only
That is the same certificate (based on the key your have) in use now.
All that changed is the chain.
So it should work.
If you try to use the "long chain", paste the first certificate in the Certificate box and the last two certificates in the CA bundle box. cPanel will automatically pair the key with the certificate.
On a UNIX client I simply execute the following command:
openssl s_client -connect f1ian.com:443
the output of the command tells what certificate the server sends.
It depends on the on the web interface, which I do not know. If there are no separate windows for the certificate and the chain, you paste the content of the fullchain (3 certificates). If there are separate windows available, then you paste the certificate pem file (1 certificate) into the certificate input, and the content of the chain file (2 certificates) into the chain input field.
also known as the CA bundle field in cPanel. CertSage only provides the full chain (contents of certificate.crt
) containing your leaf certificate then two intermediate certificates, in that order.
Thank you everyone so much ! It worked finally ! it seems i wasn't inserting the other certificate in the CA bundle but now i did and it works no more warning on my phone
Great!
Yes, yes, yes. This is how it looks like now:
Certificate chain
0 s:CN = f1ian.com
2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
i:O = Digital Signature Trust Co., CN = DST Root CA X3
Woohoo!
