Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
ssl validity is upto 20 MAY 2022 but my site runs in only not secure mode , not running in https://erp.zhamennagam.in . till prior to 19 FEB 2022 it runs fine in https mode , any clues to fix the issue
My domain is: erp.zhamennagam.in
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): "Ubuntu 18.04.5 LTS"
My hosting provider, if applicable, is: digital ocean
or certbot-auto --version
if you're using Certbot): certbot 1.23.0
9peppe
February 21, 2022, 9:39am
#2
Yes, that's true. crt.sh | 6210177057
But it doesn't throw errors, it goes in timeout. Like if there wasn't a server at all.
What command did you run to get and renew the certificate?
Show us the output of certbot certificates
and show us the output of grep -ir listen /etc/nginx
and grep -ir ssl /etc/nginx
$ sudo certbot certificates
Found the following certs:
Certificate Name: erp.zhamennagam.in
Serial Number: 4625d4ccc6d35a098ef716144e5b0e77988
Key Type: RSA
Domains: erp.zhamennagam.in udhayamerp.zhamennagam.in umrkterp.zhamennagam.in
Expiry Date: 2022-05-20 22:13:51+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/erp.zhamennagam.in/fullchain.pem
Private Key Path: /etc/letsencrypt/live/erp.zhamennagam.in/privkey.pem
$ grep -ir listen /etc/nginx
/etc/nginx/sites-available/default: listen 80 default_server;
/etc/nginx/sites-available/default: listen [::]:80 default_server;
/etc/nginx/sites-available/default: # listen 443 ssl default_server;
/etc/nginx/sites-available/default: # listen [::]:443 ssl default_server;
/etc/nginx/sites-available/default:# listen 80;
/etc/nginx/sites-available/default:# listen [::]:80;
/etc/nginx/nginx.conf:# listen localhost:110;
/etc/nginx/nginx.conf:# listen localhost:143;
$ grep -ir ssl /etc/nginx
/etc/nginx/sites-available/default: # SSL configuration
/etc/nginx/sites-available/default: # Note: You should disable gzip for SSL traffic.
/etc/nginx/sites-available/default: # Read up on ssl_ciphers to ensure a secure configuration.
/etc/nginx/sites-available/default: # Self signed certs generated by the ssl-cert package
/etc/nginx/nginx.conf: # SSL Settings
/etc/nginx/nginx.conf: ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
/etc/nginx/nginx.conf: ssl_prefer_server_ciphers on;
/etc/nginx/snippets/snakeoil.conf:# Self signed certificates generated by the ssl-cert package
/etc/nginx/snippets/snakeoil.conf:ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem;
/etc/nginx/snippets/snakeoil.conf:ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
9peppe
February 21, 2022, 9:56am
#4
Show us this file.
Is there nothing in /etc/nginx/sites-enabled
Did you switch servers?
yes nothing in that file
9peppe:
no i didnot switch server
9peppe
February 21, 2022, 10:03am
#6
Tell me the output of
ss -tlpn | grep ':80 '
ss -tlpn | grep ':443 '
(if there is no ss
on ubuntu 18.04, use netstat -tulpn | grep ':80 '
and netstat -tulpn | grep ':443 '
9peppe:
$ ss -tlpn | grep ':80 '
LISTEN 0 511 0.0.0.0:80 0.0.0.0:*
9peppe:
no output its not listen
9peppe
February 21, 2022, 10:06am
#8
what's the sixth column?
tkdhanasekar:
this means nginx is not listening on the https port.
MikeMcQ
February 21, 2022, 3:10pm
#9
tkdhanasekar:
9peppe:
Might need sudo ss -tlpn | grep ':80'
to see sixth column
ssl details and server block missing in /etc/nginx/conf.d/erpnext.conf
added the details , now the server runs in https ,
$ sudo ss -tlpn | grep 443
LISTEN 0 511 0.0.0.0:443 0.0.0.0:* users:(("nginx",pid=10895,fd=8),("nginx",pid=10893,fd=8))
thanks for the inputs
system
closed
March 24, 2022, 5:27am
#11
