SSL/TLS certificate changed and is invalid
My domain is: https://loobynet.co.uk
I ran this command: Went to send an email
It produced this output: see image and topic title
The operating system my web server runs on is (include version): Don't know
My hosting provider, if applicable, is: 123reg.co.uk
I can login to a root shell on my machine (yes or no, or I don't know): Don't know
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, cpanel, but using certsage to handle the certificates
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): n/a
Hi all -- I went to send an email from my domain and got the message in the image here. I clicked accept and all went well, but is there anything I should be doing in future?
Are you using tsoHost or Godaddy?
You need a cert covering your mail subdomain to use it properly.
Yes -- I think TSO was taken over by GoDaddy.
Is it as simple as using your (excellent!) tool and going to CertSage and adding mail.loobynet.co.uk ?
Thanks :slightly_smiling_face: and yep, you can add the mail subdomain to your cert currently covering your apex (non-www) domain name and www subdomain name (and possibly other cPanel-related subdomain names under that apex domain name).
BTW, you should probably update your CertSage. I've added a lot of useful things since your version. :grin:
Great, thanks pal, I'll get on that now.
CertSage now supports autorenewal.
