I ran this command: Adobe BC handle this, we just click ‘Add’
It produced this output: ‘Pending’ Status but for 2+ days. Other domains go to ‘Active’ within 1 hour.
My web server is (include version): Adobe Business Catalyst
The operating system my web server runs on is (include version): Dot Net
My hosting provider, if applicable, is: Adobe Business Catalyst
I can login to a root shell on my machine (yes or no, or I don’t know): N/A
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Adobe Business Catalyst
We’ve done various tests with other domains and all go to ‘Active’ very quickly. This one has failed but just says pending. Please can it be put through manually or reset or something? Would it be because the domain already has an SSL certificate elsewhere? The client is asking if you use a CAA (Certification Authority Authorization) verification check before issuing a new certificate?
Thanks. This is really urgent, the site was meant to be live on Monday.
Just before I go back to the client I’d like to confirm that from your end the WWW appears differently when you do the check because the checker I used shows them both the same. I don’t want to tell the client they’re different if they’re not. If they’re the same any idea why one works and one doesn’t?
