My domain is:http://www.grabadiesel.com/
I ran this command: none
It produced this output: none
My web server is (include version): php
The operating system my web server runs on is (include version): linux
My hosting provider, if applicable, is: godaddy
I can login to a root shell on my machine (yes or no, or I don’t know): no
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): NA
or certbot-auto --version
if you’re using Certbot): Not available
Hi @MansoorV12
you have ipv4 - and ipv6 addresses ( grabadiesel.com - Make your website better - DNS, redirects, mixed content, certificates ):
Host |
T |
IP-Address |
is auth. |
∑ Queries |
∑ Timeout |
grabadiesel.com |
A |
216.130.188.93 |
yes |
1 |
0 |
AAAA |
2607:f1c0:100f:f000::276 |
yes |
www.grabadiesel.com |
A |
216.130.188.93 |
yes |
1 |
0 |
AAAA |
yes |
But your ipv6 - https isn't configured, your ipv4 has the wrong certificate.
The certificate
CN=www.santaclaramotors.com
19.12.2018
19.03.2019
44 days expired
santaclaramotors.com, www.santaclaramotors.com - 2 entries
is wrong and expired.
As always… thanks a lot. Can you add which specific steps should I take to get it resolved?
There is no certificate - crt.sh | grabadiesel.com
So start with the basics:
Then select a client.
Hi sir, could you please check if the ssl is locked in this case or is it not locked? like Rate Exceed?
Let me know sir as we think it is locked due to Rate Exceed
Please read the basics, that answers your question.
system
closed
#8
