Sir my domain is crazywhims.com
I have created ssl with bitnami after 3 month ssl expire
now when i renew it says reach rate limit should i wait for week or do what please help me
Hi @bhj
there is a check of your domain, ~~ one hour old - https://check-your-website.server-daten.de/?q=crazywhims.com#ct-logs
You have created 5 identical certificates.
Issuer | not before | not after | Domain names | LE-Duplicate | next LE |
Let's Encrypt Authority X3 | 2019-11-16 | 2020-02-14 | crazywhims.com, www.crazywhims.com | ||
2 entries | duplicate nr. 5 | next Letsencrypt certificate: 2019-11-22 15:29:22 | |||
2 entries | duplicate nr. 4 | ||||
2 entries | duplicate nr. 3 | ||||
Let's Encrypt Authority X3 | 2019-11-15 | 2020-02-13 | crazywhims.com, www.crazywhims.com | ||
2 entries | duplicate nr. 2 | ||||
2 entries | duplicate nr. 1 |
So that part has worked, you don't need a new certificate.
How did you create these certificates?
Please answer all questions:
or certbot-auto --version
if you're using Certbot):
But you don't use your older certificate, instead, you use a self signed certificate:
CN=www.example.com, OU=Certificate generated at boot time, O=Bitnami
18.11.2019
15.11.2029
expires in 3649 days
Bitnami has different options to install a certificate. So check the documentation to find a working solution. Some users use scripts, some users create the required files manual.
Thanks for reply sir please guide me how I can fix this problem I am not good at bitnami commands I use internet help but if my certificate are not expire then why ssl is giving warning message on site your connection to this site is not private. please sir give me help so that I will follow and remove this error or should I wait for 7 days as rate limit reached.
Please sir help me I have only few questions how much time I have to wait so that rate limit will reset should I wait for 7 days or 5 and I have deleted my instance on since duplicate created , and if deleted instance on Google cloud platform without revoking SSL certificate what I have to do create again or certificate deleted and I can create new after getting new rate limit please I am new to this ignore my mistake thanks waiting for your reply.
Hi @bhj,
All of these rate limits are completely automated—enforced by software, not by human beings.
While nobody will get angry with you for exceeding the rate limit, there is also nobody who can reset or change it for you. Revoking certificates also doesn’t affect the rate limit at all; it’s calculated based on the time of creation of the certificates, not on whether they are valid or not.
You can read about the details at
Normally, you would have to wait for 7 days after the original creation of the oldest duplicative certificate. Or you could request a certificate containing an additional subdomain (like subdomain.crazywhims.com
), assuming that subdomain exists in DNS and is pointed to your server; this certificate would not be considered an exact duplicate, so a more lenient rate limit would apply to it.
