VirtualHost configuration:
*:443 is a NameVirtualHost
default server www.concretise.ca (/etc/apache2/sites-enabled/concretise-le-ssl.conf:2)
port 443 namevhost www.concretise.ca (/etc/apache2/sites-enabled/concretise-le-ssl.conf:2)
alias wwwconcretisessl
port 443 namevhost concretise.ca (/etc/apache2/sites-enabled/concretise-le-ssl.conf:22)
alias concretisessl
port 443 namevhost discord.concretise.ca (/etc/apache2/sites-enabled/discord-le-ssl.conf:2)
alias discordssl
port 443 namevhost www.intensy.org (/etc/apache2/sites-enabled/intensy-le-ssl.conf:2)
alias wwwintensyssl
port 443 namevhost je.concretise.ca (/etc/apache2/sites-enabled/jeconcretise-le-ssl.conf:2)
alias jeconcretisecassl
port 443 namevhost mokatkreation.tk (/etc/apache2/sites-enabled/mokatkreation-le-ssl.conf:2)
alias mokatkreationssl
port 443 namevhost www.mokatkreation.tk (/etc/apache2/sites-enabled/mokatkreation-le-ssl.conf:29)
alias wwwmokatkreationssl
port 443 namevhost pixabay.concretise.ca (/etc/apache2/sites-enabled/pixabay-le-ssl.conf:2)
alias pixabayssl
port 443 namevhost webmail.concretise.ca (/etc/apache2/sites-enabled/webmail-le-ssl.conf:2)
alias webmailssl
*:80 is a NameVirtualHost
default server www.concretise.ca (/etc/apache2/sites-enabled/concretise.conf:1)
port 80 namevhost www.concretise.ca (/etc/apache2/sites-enabled/concretise.conf:1)
alias wwwconcretise
port 80 namevhost concretise.ca (/etc/apache2/sites-enabled/concretise.conf:18)
alias concretise
port 80 namevhost discord.concretise.ca (/etc/apache2/sites-enabled/discord.conf:1)
alias discord
port 80 namevhost www.intensy.org (/etc/apache2/sites-enabled/intensy.conf:1)
alias wwwintensy
port 80 namevhost je.concretise.ca (/etc/apache2/sites-enabled/jeconcretise.conf:1)
port 80 namevhost www.mokatkreation.tk (/etc/apache2/sites-enabled/mokatkreation.conf:1)
port 80 namevhost mokatkreation.tk (/etc/apache2/sites-enabled/mokatkreation.conf:18)
alias mokatkreation
port 80 namevhost pixabay.concretise.ca (/etc/apache2/sites-enabled/pixabay.conf:1)
alias pixabay
port 80 namevhost webmail.concretise.ca (/etc/apache2/sites-enabled/webmail.conf:1)
alias webmail
<VirtualHost *:80>
ServerName www.concretise.ca
ServerAlias wwwconcretise
DocumentRoot /var/www/intensy/concretise
<Directory /var/www/intensy/concretise>
Options -Indexes +FollowSymLinks
AllowOverride All
Require all granted
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.concretise.ca [OR]
RewriteCond %{SERVER_NAME} =concretise.ca
</VirtualHost>
<VirtualHost *:80>
ServerName concretise.ca
ServerAlias concretise
AllowOverride All
Require all granted
</Directory>
RewriteEngine on
</VirtualHost>
<VirtualHost *:443>
ServerAlias wwwconcretisessl
AllowOverride All
Require all granted
</Directory>
SSLCertificateFile /etc/letsencrypt/live/concretise.ca/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/concretise.ca/privkey.pem
</VirtualHost>
</IfModule>
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerAlias concretisessl
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
</IfModule>
But this change doesn't solve my problem
I'm not sure.... it was 1 /2 and now 1/20
solve or not... I will try some day...
All those short-named aliases should just be removed.
They serve no purpose.
And I also see WP redirecting:
X-Redirect-By: WordPress
And certbot
added redirections in Apache
Sounds like one too many redirectors.
Where?
About htaccess it's already removed, I removed because it didn't work
curl -Ii https://concretise.ca/.well-known/acme-challenge/Test_File-1234
Date: Sat, 04 Jun 2022 02:14:52 GMT
Server: Apache/2.4.53 (Debian)
Expires: Wed, 11 Jan 1984 05:00:00 GMT
Cache-Control: no-cache, must-revalidate, max-age=0
Location: https://www.concretise.ca/.well-known/acme-challenge/Test_File-1234
Is it better now? I removed an extension
I still see the same things.
But I don't know that I ever saw the error you are complaining about.
When you tape the url http://www.concretise.ca, you never receive site is not secured sometime? You must disable auto-https from browser
My test browser won't auto http to https.
Is seems to always redirect for me.
it seem correct right nowbut it didn't work half of time this afternoom
After many tries I consider this post as solved! Thank you guys @rg305 @griffin for your time and skills
