SSL on Zimbra issue
/opt/zimbra/bin/zmcertmgr deploycrt comm mail.zimbra-mazen.cloudns.ph.cer fullchain.cer
** Verifying 'mail.zimbra-mazen.cloudns.ph.cer' against '/opt/zimbra/ssl/zimbra/commercial/commercial.key'
Not an RSA key
ERROR: Certificate 'mail.zimbra-mazen.cloudns.ph.cer' and private key '/opt/zimbra/ssl/zimbra/commercial/commercial.key' do not match.
I guess you have an ECDSA key. How did you get your certificate?
/root/.acme.sh/acme.sh --issue -d mail.zimbra-basem.cloudns.biz --standalone --server letsencrypt --force
thank u for helping if u have any suggestions reply to me please
Please don't use --force
I think acme.sh uses this switch to make you select if you want an rsa certificate, just add -k 2048 to your command.
  -k, --keylength <bits>            Specifies the domain key length: 2048, 3072, 4096, 8192 or ec-256, ec-384, ec-521.
so generate new certs or is there any way to delete the old one
or no need for that
You can keep the old cert.
I want only to generate cert foe zimbra if u have any doc for that or easy way that would be helpfull also
I don't know. Never used zimbra. What does
acme.sh --list
show?
Ok, you do have an ecdsa certificate. You need an RSA one.
What happens if you run this? Do you get a certificate or an error?
/root/.acme.sh/acme.sh --issue --keylength 2048 -d mail.zimbra-basem.cloudns.biz --standalone --server letsencrypt
i did not try
Installing a LetsEncrypt SSL Certificate - Zimbra :: Tech Center
Zimbra with Let’s Encrypt Certificates a step-by-step guide (update) - Zimbra : Blog
Zimbra's zmcertmgr tool currently only works for RSA keys, but you can use this patch to make it accept ECC keys as well:
Zimbra confirmed this fix will be part of the next patch release.
Tested working :100:% using OpenSSL 3.0.2 [with RSA and ECC certs]
Thanks @ghen for this much needed improvement!
Now if they could only figure out how to use anything other than RSA certs for DKIM [RFC 8463]...
[not holding my breath for that]
