SSL on Ubuntu 16.04 with apache and varnish
If you hit the 25 limit (Again)
Click on my name and choose the" message" option (for direct message)
No I mean the whole work that needs to be done. I don’t touch vim, all my stuff is done via nano.
Man I am still missing some stuff, but I can’t be bothering you. I mean you already shown me some stuff and helped me along the line.
Proxypass returned an error on apache. So I tried to see the apache modules I was using by giving apache2ctl -M to see if mod_ssl and mod_proxy was enabled.
And then this happened:
SSLCertificateFile: file '/etc/letsencrypt/live/leptokaropoulos.gr/fullchain.pem' does not exist or is empty
EDIT:
I will be troubleshooting this stuff for now and see where I am at. I am super thankfull for your help. You are what makes open source and its community so admirable and loveable. This is the only way forward!
If I have another problem I will be posting again in a new thread.
Thanks for all the help mang. Hope to see you around.
You have twitter btw?
That sounds like a permissions problem.
ls -l /etc/letsencrypt/live/leptokaropoulos.gr/
I only use twitter for ā€œbusinessā€.
Best of luck to you :slight_smile:
Should I be free with permissions on such files?
ls: cannot access '/etc/letsencrypt/live/leptokaropoulos.gr/': Permission denied
I wasn't going to bother you with questions. Just to follow :slight_smile:
"Yes", apache should be able to read that directory.
It must, to be able to use the cert.
Don't look it down so tight that no one can use it - LOL
Again thank you very much. I think proxy is also enabled and LE also enabled. Fingers crossed!
The next thing I will be troubleshooting is why my certificate isn’t trusted on the browser.
Thank you man. See you around I guess! Much love
I have a few more minutes before I have to go...
Try:
I will be keeping that thought in my head for the rest of the day - thank you for that :slight_smile:
You need to set the cipher preference order:
https://www.ssllabs.com/ssltest/analyze.html?d=leptokaropoulos.gr
Use:
SSLHonorCipherOrder On
It should be included in:
/etc/apache2/conf-available/other-vhosts-access-log.conf
Show:
ls -l /etc/apache2/conf-enabled
and
cat /etc/apache2/conf-available/other-vhosts-access-log.conf
I did it. However still not secure. But those sites have instructions that I will follow. Again thank you for everything, man. You helped a fellow human today and you should be proud for it. Thank you friend! :slight_smile: See ya!
Peace out!
Stay dangerous.
