My domain is:https://joshlevisalon.com/
sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challenges dns certonly
What would you like to do?
1: Keep the existing certificate for now
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/joshlevisalon.com/fullchain.pem
/etc/letsencrypt/live/joshlevisalon.com/privkey.pem
Your cert will expire on 2020-05-21. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
“certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
bitnami@ip-172-31-10-94:~$
Server version: Apache/2.4.39 (Unix)
Server built: Jun 7 2019 10:45:27
bitnami
godaddy
no
or certbot-auto --version
if you’re using Certbot):
