Hi -
I have used certbot in the past with success to issue SSL certs but am having an issue with a .io domain. I used certbot --apache -d blueseas.io -d www.blueseas.io command to issue a cert and everything seemed to go okay. However when I browse to the URL in question is shows up as a mismatched, when i viewed the cert in chrome it showed it was issued by and for localhost? Are .io domains supported? What am I doing wrong if so? Searched for a similar issue but couldn’t find one. Help is much appreciated. Thanks!
