My nginx.conf is:
events {
worker_connections 1024;
http {
server_tokens off;
charset utf-8;
listen 80 default_server;
server_name _;
location ~ /.well-know/acme-challenge/ {
root /var/www/certbot;
return 301 https //$host$request_uri;
listen 443 ssl http2;
ssl_certificate /etc/letsencrypt/live/dogyt.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/dogyt.com/privkey.pem;
server_name dogyt.com;
client_max_body_size 108M;
access_log /var/log/nginx/application.access.log;
root /var/www/html;
index index.php index.html index.htm;
# try to serve file directly, fallback to index.php
proxy_pass http://helloworld:8000/;
# try_files $uri /index.php$is_args$args;
if (!-e $request_filename) {
rewrite ^.*$ /index.php last;
location ~ \.php$ {
fastcgi_pass php-fpm:9000;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PHP_VALUE "error_log=/var/log/nginx/application_php_errors.log";
fastcgi_buffers 16 16k;
fastcgi_buffer_size 32k;
include fastcgi_params;
My Docker Compose is:
networks:
mynetwork:
driver: bridge
ipam:
config:
- subnet: 1.1.1.0/16
gateway: 1.1.1.1
services:
postgres:
image: 'postgres:14.12'
working_dir: /application
volumes:
- '.:/application'
environment:
POSTGRES_USER: ${DB_USUARIO}
POSTGRES_PASSWORD: ${DB_SENHA}
POSTGRES_DB: ${DB_BANCO}
ports:
- '5432:5432'
networks:
mynetwork:
ipv4_address: 1.1.1.3
webserver:
image: 'nginx:alpine'
restart: unless-stopped
volumes:
# - .:/application
- ./phpdocker/nginx/nginx.conf:/etc/nginx/conf.d/default.conf
- ./certbot/conf:/etc/letsencrypt
- ./certbot/www:/var/www/certbot
ports:
- 80:80
- 443:443
networks:
- mynetwork
depends_on:
- postgres
certbot:
image: 'certbot/certbot'
volumes:
command: certonly --webroot -v -w /var/www/certbot --force-renewal --email igor.o.crisostomo@gmail.com -d dogyt.com --agree-tos
php-fpm:
build: phpdocker/php-fpm
volumes:
- '.:/application'
- './phpdocker/php-fpm/php-ini-overrides.ini:/etc/php/8.3/fpm/conf.d/99-overrides.ini'
networks:
- mynetwork
Why this error?
certbot-1 | Domain: dogyt.com
certbot-1 | Type: connection
certbot-1 | Detail: 82.180.162.136: Fetching http://dogyt.com/.well-known/acme-challenge/6hcnkruIrA3EOD6Wn9BP8RLczrLZ3Cyx6ifzy9nT6HI: Connection refused
certbot-1 |
certbot-1 | Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
certbot-1 |
certbot-1 | Some challenges have failed.
certbot-1 | Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
