Some browsers not showing my SSL in one of my State of origin rugby site.
We’re gonna need some more information… What do the browsers show? Is it an error? A red padlock? No padlock?
What browsers work or don’t work? Is it consistent?
The website itself shows that it’s serving a certificate properly in a compatible method for all major browsers. (Even if it’s doing so somewhat insecurely.) https://www.ssllabs.com/ssltest/analyze.html?d=stateoforigin2018.com
There are no 128-bit CBC ciphersuites in your configuration, which will cause compatibility issues with some browsers and middleboxes.
If you’re not sure what that means I recommend you just use the Mozilla-reccomended Intermediate SSL Configuration.
