I issued an SSL (and as it seems lets encrypt did issued it) to my domain, yet still not working.
Used certbot, when I run on my Windows server certbox certificates it show as valid.
Could someone help?
https://login.magicom.app:3000
That is the domain, Chrome says it is SSL ERR still.
Attached is the output of certbot on my server
Here is a list of certificates issued crt.sh | magicom.app, the latest being 2022-11-17.
The one for login.magicom.app is crt.sh | 7998686044, is the one certificate being used?
I also get this when I use Windows 10 Firefox 107.0 (64-bit), is that expected? As I do not know what I should expect on port 3000 with HTTPS protocol.
The RECORD_TOO_LONG error indicates that your server is speaking HTTP while the client is (trying to) speak HTTPS. A connection to http://login.magicom.app:3000 succeeds, and redirects to https://login.magicom.app:3000. The latter fails, likely because you can't really do both HTTP and HTTPS on the same port.
Yeah as @Bruce5051 suggests it would help if you can step back a bit and explain what type of service this is? e.g. Apache httpd, Apache Tomcat, nginx, caddy or a custom server type. How you configure SSL varies depending on which software product you are trying to configure.
Currently you may well have a valid certificate file, but your software isn't configured to use https (yet).
Quick question: after you've issued the cert with Certbot, what steps did you take to actually install the certificate into whatever unmentioned app you've got running?
Well, I read this twice and still not clear how do I apply it on my server.
My programmer for the project quit so, cannot ask him. what should I do in my server so it would work?
I understand that I miss something, which you say is to let the app to use SSL.
How do I do it?
As your server is an Express app running in NodeJS then without a programmer you will be unable to proceed. You'll either need to learn programming enough to work on the app yourself or get another programmer.
