SSL installed, but will only work if I use the https:// protocol. my domain name is testedandtrusted.com.ng … if I type the domain name to the address bar, it will load and say not secure, unless I manually put the https protocol
Hi @Bayo
sounds like you don't have redirects http -> https.
Yep, checked your domain via https://check-your-website.server-daten.de/?q=testedandtrusted.com.ng
You have a new certificate.
CertSpotter-Id | Issuer | not before | not after | Domain names | LE-Duplicate | next LE |
962690111 | CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US | 2019-06-12 00:41:05 | 2019-09-10 00:41:05 | mail.testedandtrusted.com.ng, testedandtrusted.com.ng, www.testedandtrusted.com.ng - 3 entries | duplicate nr. 1 |
But your connections:
Domainname | Http-Status | redirect | Sec. | G |
• http://testedandtrusted.com.ng/ | ||||
31.31.196.194 | 200 | 0.163 | H | |
• http://www.testedandtrusted.com.ng/ | ||||
31.31.196.194 | 200 | 0.167 | H | |
• https://testedandtrusted.com.ng/ | ||||
31.31.196.194 | 200 | 0.694 | N | |
Certificate error: RemoteCertificateNameMismatch | ||||
• https://www.testedandtrusted.com.ng/ | ||||
31.31.196.194 | 200 | 0.607 | N | |
There is no redirect http -> https. And the certificate is wrong.
CN=*.hosting.reg.ru, OU=Domain Control Validated
24.01.2019
25.01.2020
expires in 227 days
*.hosting.reg.ru, hosting.reg.ru - 2 entries
So first you should install the certificate. Then add redirects http -> https.
