SSL for Synology's Quickconnect?
#1
I am pretty new to this NAS setup, so I am trying to configure all securities prior to storing my data on it.
For the SSL setup, I have couple of questions:
  1. I have enabled DDNS and I was able to set up the SSL. And this works great.
    My understanding here is: DDNS would map a domain(Synology’s) to my NAS’s static Ip address. And I got the little padlock after I setup the Lets Encrypt certificate.
  2. There is this QuickConnect account setup as well. Where on the desc. it says: It would connect our diskstation from anywhere. Then my domain would looks like something: http://QuickConnect.to/my_Id.
    How can I establish SSL for this above url?
Also how these both: DDNS and QuickConnect would differ each other.
What url I need to use to access my NAS from anywhere(DDNS/QC)? And how I can successfully have the SSL setup on the QC, if at all I need to use it?
#2
From synology’s document, you should use the QC for any file sharing, and DDNS for regular website / hosting.
You could try to follow this guide (However, since I don’t have an Synology NAS, I’m not sure if that tutorial is correct.)
https://www.synology.com/en-us/knowledgebase/DSM/help/DSM/Tutorial/cloud_set_up_quickconnect
If this guide does not work out, you might want to ask an Synology customer care representative…
Thank you and merry Christmas
